testing Jerry's steel cone styli
Fela Borbone
Re: testing Jerry's steel cone styli
Post: # 30163Unread post Fela Borbone
Mon May 19, 2014 10:38 am
Triangles intended for cutting also work well when used for embossing if mounted front side back. As I said in other thread, no need to tilt the head.
Quiet (when unnmodulated) gooves and good tracking.Nice and cheap.
Tried in a Rek o kut. Presto and Audax heads. lexan policarbonate, no heat.
sunkingrecords
Post: # 31982Unread post sunkingrecords
Fri Oct 24, 2014 9:36 am
Hi!
What kind of shank those this steel stylus have? I wonder if I can use them in the Angulo machine. Currently I'm running with Adamant NSH-2S, but I'm yet to get practice at embossing, and I'm deteriorating the sapphire very fast by mishandling it!
Also, how do you clean, if you clean at all, the lighter fluid once the record is made?
Kind regards
Miguel
I choose not to run .-
