Piezo ceramics as cutting head drivers?
grooveguy
Re: Piezo ceramics as cutting head drivers?
Post: # 56350Unread post grooveguy
Sun Jul 26, 2020 6:20 pm
It would be good to know what sort of 'stroke' the injector has, either from direct actuation or with the aid of the Hydraulic Amplifier. It would seem to me that a squirt of fuel requires quite a bit of displacement, and that maybe even the 'short stack' might move a cutting stylus sufficiently to modulate a (micro)groove.
Tinplate
Post: # 56351Unread post Tinplate
Mon Jul 27, 2020 7:10 am
Today I understood that the mechanical lever in direct type injectors is not used to extend the movement, but to reverse its direction (the injector must be open when voltage is applied, not when there is no voltage). In the senis of using injectors, I thought of them as the source of the piezo stack, omitting (cutting off) the entire chydraulics or mechanics (connecting cutterhead push rod directly to push pin from stack). I suspect that such a stack has its internally determined tension imposed by the stack casing or some other element. It is possible that when the mechanical lever is removed, the piezo stack will lose its pre-determined tension. These are just assumptions. Maybe it's time to buy and destroy a few injectors. :wink:
grooveguy
Post: # 56352Unread post grooveguy
Mon Jul 27, 2020 11:40 am
Sounds like a plan. I've got a feeling those injectors don't come cheap. Maybe a wrecking yard? Who supplies the piezo stacks? Maybe someone like TDK; should be possible to get just that part.
uvoscillator
Post: # 66849Unread post uvoscillator
Wed Feb 12, 2025 4:18 am
hey guys, any updates on experiments with pzt?
I am also recently explored modern world of piezo stacks and stuff for myself, huge list of reading to proceed !
this is probably not a cheap story unfortunately for diy experiments, but very interesting anyway as anything related to cutting hehe :twisted:
scanning tubes looks very promising at first look, like they where born to cut, but nah, any added even insignificant weight on moving tip lowering resonance freq dramatically,
but cool concept anyway
So if anyone have something new to add, it will be great to hear any progress !
I've googled in case someone also get this ideas, found only this mention of concept by Phillip Salisbury for DDM, 10 years ago
but nah, it also takes time to find this tread :D
https://www.coroflot.com/phillipsalisbury/Vinyl-Stereo-Cutter-Head
Cheers !
Best !
