Who can help me with my VR T560 cutterhead?
ROLANDJAYS
Re: Who can help me with my VR T560 cutterhead?
Post: # 43031Post ROLANDJAYS
Sat Jun 18, 2016 3:18 pm
I bought some souri tweeters and will be making a head with them and a Neumann torq tube and v spring.
coming up!
thanks to everyone's hard work , maybe we can have an actual low cost cutter head . :D :D :D
socialroots
Post: # 43033Post socialroots
Sat Jun 18, 2016 10:31 pm
Great news coming from a great machinist, Im hoping that it will be able to mount on my ROK m12! Ive asked about the mounting bracket before cuz I wanted to swap out my stock cutterhead that came with my challenger, didnt order it yet cuz I was waiting on a cutterhead solution that I could afford to come into picture, ive got my fingers crossed one this one!
amaximum respect,
Patrick
ROLANDJAYS
Post: # 43055Post ROLANDJAYS
Tue Jun 21, 2016 2:37 am
did you want to know how heavy it is?
if i remember correctly it was 50 -60 grams
Snug Music
Post: # 43116Post Snug Music
Mon Jun 27, 2016 10:49 am
short update,...
we had heavy static problems. have very much tried. Wax, denoiser etc.
But the best thing we have made:
A comb made of carbon fibers (connected to earth), glides over the disk surface.
Since then we have zero problems with Static charge !!!
further updates and the new Cutter Head follow in the coming days.
best regards Scotty
ROLANDJAYS
Post: # 43277Post ROLANDJAYS
Mon Jul 11, 2016 10:28 pm
:D
cosmO_O
Post: # 43300Post cosmO_O
Wed Jul 13, 2016 11:43 am
With some freetime, i made adjustments and a few new cones, almost 0,5 gram :D
I start to solder brass parts with moderate success, i really need a neumann styli, just for to make a taper hole, but now im on low budget no money for a new myshank one :(((
ROLANDJAYS
Post: # 43306Post ROLANDJAYS
Wed Jul 13, 2016 10:25 pm
that looks good ! is it 3d printed?
cosmO_O
Post: # 43307Post cosmO_O
Thu Jul 14, 2016 3:30 am
ROLANDJAYS wrote:that looks good ! is it 3d printed?
Thanks! Of course, 100 micron layer height, 0,5 mm thickness :)
Snug Music
Post: # 44214Post Snug Music
Tue Oct 04, 2016 2:11 am
hi people ... after my accident, I am finally back! What's in my state of affairs? Current status: Our Lathe has improved a lot! Variable groove pitch (width and depth!), Feed Crew = sensorcontroled (position). Grounded brushes as a comb (these are operated via the platter!) Thus prevent complete a Static Charge.(Static charge = 0% !!!) Cutting head is completely earthed !!! Cutting head is not a feedback head !!! Analog Endmastering !!! Thats it! The result we achieved with this is absolutely brilliant! + 12dB, total noise free, brilliant treble, crisp bass. We are more than satisfied !!!!!!
best reguards Scotty
i will be back... 8) :mrgreen:
GEEKKCC
Post: # 51902Post GEEKKCC
Thu Dec 13, 2018 10:23 pm
Hi Trolls and friends, i bought the vinyl recorder from Souri 4 months ago.
Great machine and a great man, everything was great until we moved studio space and then we encountered a humming sound from the Amplifier from souri, so we decided to change the plug into several different 13amp mains sockets around the room, somewhere better and some were worse, however, there is a slight hum when you turn the amp on when cutting with no music, turn off the amp it sounds fine and clean. I have a few questions as a noob and need to work out a few things.
1. SOURIS MIXER VOLUME AND GAIN IS CONTROLLED BY THE PFL AND THE CHANNEL 2 FADER, I CAN NOT FIND THE BALANCE RIGHT UNLESS I HAVE THE PFL KNOB REALLY LOW (WHICH DAMPENS THE HUM AND GETS RID OF IT ALMOST) BUT THEN THE CUTS ARE REALLY LOW AND IF I WAS TO TURN THE GAIN UP THROUGH THE FADER IT WILL DISTORT and sound bad.
2. BAD FREQUENCY ISSUES WITH HIGHS AND BRIGHTNESS, WE GO FROM DIGITAL TO POLY AND POLY THERE IS A LACK OF HIGHS AND PUNCH, ITS VERY DARK AND NOT WELL ROUNDED. Why could this be?
3. GROUNDING LOOP OR WRONG ROUTINE OR STYLUS ISSUES (EVEN THOUGH HAVE A BRAND NEW NEEDLE)
4. THE MACHINE WAS PERFECT BEFORE CHANGING A FEW PHONOS FOR THE BETTER
PLEASE HELP
THANKS
GEEKKCC
Post: # 51904Post GEEKKCC
Thu Dec 13, 2018 10:28 pm
PLEASE HELP
THANKS
rubenr
Post: # 52210Post rubenr
Sun Jan 27, 2019 5:59 am
Friday 25-01-2019 23:15 Austria:
I coneccted first de Amp 380x 380, and after the power supply, AND CLIC " POP " BOOOM, The left tweeter was broken.
OK 2 days after, whit 4 hours sleep whit my eyes reds for too much computer, i told yoou some think,
1 First use fuse 1A o Whit minus A.
2 NEVER more make on the amp first.
3 read all forum , al post, investigue all.
4 make broken the conical form from tweeter.
5 Put one meter in your hand and enjoy.
6 Buy, 2 diferents models Pro-Tech 200W 2/419 buyed, Rockville RT6 240 W buyed.160 euros in total. and stay in relax for many days. but all 25mm
7 Whit a lot nervius searching for 36 hours, no sleep, only cafe and find the "original tweeter" (NX30 - Image Dynamics 30MM)
8 Sleep, 4 hours. whit nightmares about the machine.
9 You can write your history, and put in the forum.
10 ...... Next week more steps.
Maybe helps.
https://www.templatemaker.nl/index.php?template=cone&lang=es
https://www.ebay.com/itm/123592878889 for test, i want no more things broken.
https://www.red-carparts.de/car-hifi/car-hifi-auto-lautsprecher/hochtoener/phonocar-hochtoener-tweeter-pro-tech-200w-2-419
https://www.rockvilleaudio.com/2-rt6/
https://www.woofersetc.com/p-4996-nx30-image-dynamics-30mm-silk-dome-tweeters-with-rotating-flush-mount-socket.html
I think need it. I need one feedback in my email. https://www.woofersetc.com/c-172-speakers/c-24-tweeters/p-5718-xs-28-image-dynamics-28mm-silk-dome-tweeters-pair.html
Best regards Rubén.
dubvinyls.com
rubenr
Post: # 52215Post rubenr
Sun Jan 27, 2019 3:04 pm
I m very happy, after three days of searching, I asked directly Souri and he will offer me support to repair and fix it. So, despite of all comments about him, I am still thinking that he is great. He always responds my Emails, so my decision is to send it to him. I won't experiment more with the original machine, but since I have ordered new Tweeters, I will try thing with them.
Best Regards! And ask allways him! SOURI IS THE BEST !
Rubén Rubio
rubenr
Post: # 52376Post rubenr
Fri Feb 15, 2019 9:38 am
After a bad experience with that man, I will try to try my luck for myself, after all, it was my mistake to try to send something to a guy who shows very little gray matter.
Yesterday I bought that glue, but it does not help me, this morning I bought that epoxi, my idea is to give it a good bath and let them rest.
A friend of the forum told me to take the test with aluminum, luckily my neighbor had two cans of beer. What do you recommend me 'directly with metal? They explained to me that if I wanted to go up to 10Khz, the metal would be recommendable .. I was going to have a lot more brightness in itself.
I have 4 loudspeakers and I am waiting for it to see if my original cutting head finally arrives since after almost a month that engineer named Souri has not been able and his excuse was the silicone ring. No comment.
I have also bought sewing needles, of different sizes and diameters and this piece that I had to strengthen an Ikea bed. Now I have to put on gloves, make the mixture of resins and patience ... tomorrow I get results.
But I need your advice ... Paper with epoxy? or Beer aluminum?
https://ibb.co/8KWT7hd
https://ibb.co/D77TD6H
https://ibb.co/S0dVGyZ
https://ibb.co/rbwtHLp
https://ibb.co/m634LNp
https://ibb.co/XDWYrFQ
rubenr
Post: # 52377Post rubenr
Fri Feb 15, 2019 10:06 am
resumen.
rubenr
Post: # 52378Post rubenr
Fri Feb 15, 2019 11:41 am
first epoxy bath ;)
Post: # 52380Post opcode66
Fri Feb 15, 2019 11:25 pm
A while back I had access to a Vinyl Recorder dynamic cutterhead. I drew the body in CAD. I've exported an STL and am making it freely available to the community. Enjoy!
Here is the VR Cutterhead body as STL. DIY until your heart is filled with joy... :-)
rubenr
Post: # 52385Post rubenr
Sat Feb 16, 2019 3:44 am
Todd! No words!!! Gracias!!!!! THX ! You make me very happy :)
rubenr
Post: # 52422Post rubenr
Wed Feb 20, 2019 4:14 pm
more steps! I think this week we have a new bebe in tha house ;)
