I find it remarkable that you have patience with this project, which is truly amazing.
A beer for you !!!
Best regards from West-Germany
Scotty
It's just that I hate to give up...Snug Music wrote:I find it remarkable that you have patience with this project, which is truly amazing.
I'm not sure if you listened to the posted test cut or not. If not, it's worth doing especially to compare with the next one. Not too bad, but lacking channel separation which was disappointing to say the least.Bahndahn wrote:...I've really been enjoying your updates. You are so close you can probably hear it!
Hey Bryan,..EpicenterBryan wrote:A quick update:
Here is a really cool way to cure CA (super glue), super fast and rock hard!
Wow, that looks like colored baking soda. Perhaps the metal powder is already in there though.emidisc wrote:I have been using a product called "Supa Fix" for the last few months and it appears very similar to your baking soda method,
hey my friend,...EpicenterBryan wrote:
My head details like stylus and torque tube length, and also distance to piano wire mount need to be addressed. Spring back of the recording media was not accounted for in my head details and should be addressed with a new understanding of it's impact! Perhaps this should be done in your head too? Some of what I've learned explains why the stylus angle on the Souri head is so large.
Bryan
Scotty, I have seen that. It is not the same problem or solution to what we are working with. DMM cutting is direct in soft metal, and the metal does not spring back, and the process is more like making metal parts in a machine shop with different material issues.Snug Music wrote:Bryan, what u think about this one
EpicenterBryan wrote:Scotty, I have seen that. It is not the same problem or solution to what we are working with. DMM cutting is direct in soft metal, and the metal does not spring back......Snug Music wrote:Bryan, what u think about this one
EpicenterBryan wrote: The Benjamin B. Bauer patent "Sound recording method and apparatus" which has all the details about springback and the fix can be found here:
http://www.google.com/patents/US3490771
Glad you liked.Snug Music wrote:Bryan, the PDF is awesome !!!
Let me clarify. When the stereo information (L-R) is cut, the stylus moves up and down in an arc (vertical motion). The arc is defined by the VMA (vertical modulation angle) which is the effective angle formed from the cutting point to the end of the cantilever (the connection between the piano wire and head body). When it is played back, the playback cartridge also has a cantilever and forms an angle. On playback, it's called VTA or vertical tracking angle. The two angles must match for lowest distortion and correct stereo image. However, there is also bounce back from the material being cut that also needs to be accounted for in the cutting cantilever when the groove is actually cut. That bounce back accounts for an additional 20 degrees.sakuszi wrote:I do not understand. Where is the VTA? it seems to me that everything is anyhow, gramophone needle hits the groove side, anyhow, crooked groove mono, stereo above or below the left and right side of the groove, so I understand.
