Some exciting news for Presto or small desktop lathe users.
Also compatible with Vinyl Recorder.
I have developed and just finished a Dynamic Stereo Cutter Head only 63mm wide that is capable of cutting nice clean loud stereo cuts! Uses a Vinyl Recorder 340 Stylus.
First tests only made a few hours ago and here’s the results.
Calibration EQ (FabFilter EQ Match)
used which includes the RIAA curve and also a quick preset was used from Ozone Dynamic EQ (I think it was called smooth high end) which gently tamed the top 2 bands.
Probably not needed if not cutting so loud!
I have cuts without and was still very good but for transparency it was used for this test cut attached.
I have someone in the UK buying two of them and someone else in Italy, and if they are happy, more will be available.
Contact me for pricing. They will be made to order.
1st Test Cut Audio:
https://www.dropbox.com/scl/fo/mknzzrbadqpee18sbu4fu/h?rlkey=kpd0xq849xbnkmakeop1porb0&dl=0
- leemichael
Stereo Cutter Heads Available - Presto - Vinyl Recorder
