DIY vacuum plate
lulu
DIY vacuum plate
Post: # 66054Unread post lulu
Sun Nov 03, 2024 2:12 pm
I thought that this could help or inspire someone, I got inspired from this spinnertownblanks blog post https://spinnertownblanks.com/blogs/spinner-town-blog/diy-sp10-vacuum-platter and tried to make my own vacuum patter, bacause I was tired of warped blanks due to heating. I used old and heavy platter from an Lenco L75 turntable, carved some grooves into it, drilled a hole to the center pin, one from the top and other on the side. Then I made a cap from aluminium to connect the center pin to the vacuum, there is a small O ring in it so it spins freely. Then I connected the tube from the platter to my side channel blower that I use for the chip suction... And it worked.. :) I am attaching some photos. Maybe it helps somebody. I think it is not that hard to do and it helps a lot.
Cheers,
Lu.
lulu
Re: DIY suction plate
Post: # 66055Unread post lulu
Sun Nov 03, 2024 2:13 pm
I am sorry for the bad photo orientation, but it looked OK in my computer byfore the upload.
ilovedrums247
Re: DIY vacuum plate
Post: # 66059Unread post ilovedrums247
Mon Nov 04, 2024 7:07 am
very inspiring, thanks for sharing
PLD
Post: # 66060Unread post PLD
Mon Nov 04, 2024 10:04 am
Lovely job!
Fattcamp
Post: # 66072Unread post Fattcamp
Tue Nov 05, 2024 4:39 pm
Thanks for this! Looks great :D
spinnertownblanks
Post: # 66073Unread post spinnertownblanks
Wed Nov 06, 2024 5:02 am
Amazing work! Really great to see more innovation, using an existing platter is a great idea :)
More photo's of the spindle and 0-ring would be good for others to see. Also can we update our blog with your work added to it?
www.spinnertownblanks.com
sameal
Post: # 66085Unread post sameal
Thu Nov 07, 2024 1:39 pm
Nice work!
It looks like mine was created out of a sheet of phenolic, but making one from an existing platter saves a TON of work!
farmersplow
Post: # 66105Unread post farmersplow
Sun Nov 10, 2024 5:32 am
Hello Lu, excellent work. You can be proud of that! Very inspiring. Keep up the good work!
lulu
Post: # 66163Unread post lulu
Sat Nov 16, 2024 6:39 am
Thank you for all the nice replies, I will take some more photos of the spindle and of the piece with the o ring. I am glad if someone found this useful.
Of course, that would be great, let me know when it’s there :)
Cheers,
Lu.
discosdecorte
Post: # 66165Unread post discosdecorte
Sat Nov 16, 2024 7:02 am
Looking forward to doing my own DIY vacuum platter, but the steps of taking apart the turntable to get the spindle and drilling it terrify me :|
Best regards,
Fer
SueDenim
Post: # 66179Unread post SueDenim
Sun Nov 17, 2024 7:41 am
Agreed! Drilling the centre spindles of my precious SP-10 mkII turntables is something way too risky for me :cry:
Anyone in the UK have any experience doing this?
spinnertownblanks
Post: # 66249Unread post spinnertownblanks
Mon Nov 25, 2024 9:28 am
Joel
Post: # 67236Unread post Joel
Tue Apr 08, 2025 9:41 pm
Hi Lulu,
Got inspired and in-process making one. Are there any changes you would make on the design since putting it to use? What's the approximate size and depth of the pockets/rings? It looks like you have one outer ring for both 10 & 12 inch discs. Are you finding that sufficient to hold the outer diameter of a 12 inch disc? Thanks so much for sharing.
trailerparkjesus
Post: # 67240Unread post trailerparkjesus
Wed Apr 09, 2025 2:50 pm
Adding to this... I made one with two layers of 1/16 fine grain cork. You use a circle drawing compass to make several circles in one cork sheet (I did about 1" apart) and cut them out. Use every other circle. Then spray glue them onto the other cork sheet which is cut to the diameter of your platter. Cut two channels on each side of the platter in the top cork rings form the center pin to the last ring but not through the last ring. Then I used a weld on 3/8" hose barb for the center vacuum connection. I drilled the holes in the spindle with a drill guide and 1/8" bit and a long drill extension to reach the center pin from the side. Wait until you get your cork on before drilling anything to get the right height.
Joel
Post: # 67242Unread post Joel
Wed Apr 09, 2025 9:05 pm
This is a great idea! Could you post a picture of your end result? I've used this company called https://sendcutsend.com/ that can laser cut 1/8" thick cork fairly affordably with a provided dxf file. What size side channel (regenerative) blower in terms of HP / Watts, flow rate, vacuum pressure is recommended.
lulu
Post: # 67942Unread post lulu
Mon Jul 28, 2025 8:43 am
the pocket in the middle was too big and the suction was too strong, so the blank warped down, I had to put supports and reduce the suction, it took some fiddling, but now it works pretty good. The depth is just 1mm. I use old ELMO Rietschle side channel blower.
farmersplow
Post: # 67944Unread post farmersplow
Mon Jul 28, 2025 5:10 pm
That looks great! Great work!
(I like the dashpot - I guess it needs more oil than my car ?) - Joking aside, it looks very good.
Joel
Post: # 67950Unread post Joel
Wed Jul 30, 2025 2:05 pm
Thanks so much for the update and pics. Everything with lathes seems to take fiddling. Im prototyping a vacuum pattern with gluing 1/16 gasket (rubberized) cork to the platter. Im finding the turntable platter of my Reloop has a .010 inch up/down wobble to true up as it affects the groove depth. Anyone experiencing this?
