As you can probably see from the images, the model is a RCA MI-4896, it doesn't come with any turntables, but vibrates really good, after some light use with a fuse and an amplifier, i tried adjusting the small rod that holds the tension of the armature (horrible mistake), and after some wiggle back and forth it just broke with very minimal tension. If that wasn't necessary i tried soldering it with some hard solder but it just keeps wiggling and not doing its job. it looks to me like the stick was stuck inside the armature round piece by the means of a support to the left side, not simply soldered onto...
The head works REALLY well electrically i can tell, but this is a huge problem. I was hoping to solve it by myself but it is proven to be real difficult, can anybody give a tip? I'm trying to keep it as close as standard as possible...
Thanks a lot!
