I haphazardly stumbled across this Youtube video showing a record made with the silicone mold and resin process. This is the first example I've heard of a finished copy. The results are impressive.
http://www.youtube.com/watch?v=_zuSx0R23Go
Now the question remains, how much degradation to the mold takes place with each copy made?
Silicone molded record - it works!
- Angus McCarthy
- Aussie0zborn
Let's see.... the silcone is poured in so there is no stress, no compression, no abrasion to the mould as there is any compression moulding of vinyyl records. Unless the silicone eats through the vinyl or other materials it comes into contact with, I would say there would be no deterioration. You might need to try it and let us know.
I've tried that process EXTENSIVELY and never had successs. It may because there is so much moisture in the air up in the PAcific NW, but it always bubbles up really bad as it is setting. But, the fidelity is good if you can miss the bubbles.
