mono cutterhead modify
studiorp
Post: # 20366Unread post studiorp
Sat Jul 07, 2012 12:14 pm
Hello people, today I was thinking a interesting thing : is there someone that has tried to modify a normal mono cutterhead for transform in a stereo version insert a second coil above the first ?
In this way the channels are two but without the classic 45/45 structure...
Angus McCarthy
Post: # 20367Unread post Angus McCarthy
Sat Jul 07, 2012 3:54 pm
That was actually how the first stereo heads were built, though they intended to record one lateral channel and one vertical channel. When I first discovered the concepts of cutting I toyed with this idea as well; feed summed mono to the lateral head and difference information to the vertical head, Mid/Side style. You would have to mechanically link the two heads to a central stylus - something akin to the Westrex model, but tilted 45 degrees of course. Problems arise when you consider that all the weight would rest on the vertical-modulating head, instead of on both driving coils equally.
studiorp
Post: # 20373Unread post studiorp
Sat Jul 07, 2012 5:57 pm
I am thinking to rebuild a unique very little container divided in two parts by a plastic material for example.
In one space could be a coil from 8 ohm, the same in the other; but the important thing is that this container must have the same height of original, so all magnetism should remain below two horseshoe magnets without air gaps, but this is a theory to confirm with experiments...
For understand better the structure of my head, here there is a photo from Flo website : http://www.floka.com/pics/m2clement04.jpg
The coil is red colour
audadvnc
Post: # 20405Unread post audadvnc
Wed Jul 11, 2012 10:03 am
Transforming a mono cutterhead into a stereo one? Not likely, the mechanisms are completely different. I suppose you can convert a canoe into an airplane too, but it might be easier to start from scratch.
aussie cutter
Post: # 20447Unread post aussie cutter
Sun Jul 15, 2012 7:08 am
I'd have to agree with audadvnc
It might be easier to start from scratch...
If you have a good dig around here on trolls - you will find plenty of photos of members home made stereo heads
I've been looking into building a stereo head and from what i've seen - it would not be too complicated or expensive
To build a budget stereo head based on similar designs here on trolls can cost you as little as $50 to build, but lets face it What sort of build & sound quality could you really expect to get from $50
If you were to consider building a stereo head based on what others have done - I would reccomend taking your time & putting a little extra into your materials ie: High quality speaker coils, machined aluminium frame/housing, cones etc
Not only will you have a custom stereo head that looks good, It should be of a decent sound quality too...
studiorp
Post: # 20454Unread post studiorp
Sun Jul 15, 2012 12:08 pm
Yes, thanks people for these important answers, in effect will be better start from a new project.
