Has Anyone Ever Built an Old Style Magnetic Cutting Head
Tripp Nasty
Post: # 20715Unread post Tripp Nasty
Mon Aug 13, 2012 11:55 am
I was curious if anyone here has ever built or found plans for building a wound, horsehead magnet cutting head?
I used to be a physicist and was thinking of tackling this as a project since most of the higher end lathes with magnetic cutting heads have gotten out of my price range and I'd like to have something nicer than my crystal cutting head lathes.
I'm not looking to rig a embossing machine and I don't want to use salvaged stereo speakers. I'd like to build a simple magnetic cutting head like the Audax mono cutters and then mount it on a small home lathe.
Any suggestions on where to get more technical information about magnetic cutting heads? I've read Oliver Read's book and was looking for something a little more technical about early mono cutting heads.
Post: # 20718Unread post markrob
Mon Aug 13, 2012 12:49 pm
If you PM me with your email address, I can send you quite a bit on moving iron designs.
dubcutter89
Post: # 20726Unread post dubcutter89
Mon Aug 13, 2012 3:59 pm
Hey,
I don't have any specific "design" for a moving iron head (except the basic principle scatch),
but I read an articel which says you could (or should if your budget is low)
use an old magnetic pickup since the basic is the same.
Maybe add a stronger magnet and there you go.
Hope this helps
Lukas
45rpmdude
Re: Has Anyone Ever Built an Old Style Magnetic Cutting Head
Post: # 33360Unread post 45rpmdude
Fri Jan 30, 2015 11:00 pm
Finally someone who understands what i keep saying.. Magnetic heads are expensive..
sound better.. Thhhhhxxxxx GERRRRYYY
ROLANDJAYS
Post: # 33361Unread post ROLANDJAYS
Fri Jan 30, 2015 11:20 pm
I built an audax head... recently.....
its not hard if you have the right equipment.
first thing you need is an example to work from.
Fela Borbone
Post: # 33423Unread post Fela Borbone
Mon Feb 02, 2015 5:40 pm
I made some, une is symple, the other a bit more complicated...
armature is grampian/bbc inspired but with vertical magnetic circuit and different suspension and damping.
BTW, Rolandjays, congratulations for your work,your cutterheads looks awesome!!!
ROLANDJAYS
Post: # 33425Unread post ROLANDJAYS
Mon Feb 02, 2015 5:45 pm
Tip of the hat sir !
