Glass Stylus On Polycarbonate
Any suggestions other than surface oil or realigning the glass as this was done in this recording:
http://k007.kiwi6.com/hotlink/qsj872to28/low_level_emboss_test.mp3
I can not think of anything else besides level and groove spacing, both of which were given very wide margins on this one.
Re: Glass Stylus On Polycarbonate
http://kiwi6.com/file/bt461n4px4
I think I have done just about all I can do to get the best sound from a glass stylus with a 22 degree angle. This result was about 15 degrees in direction of rotation. Any suggestions on RIAA curve to compensate for arm resonance is welcome.
- Steve E.
- Site Admin
I think you are an innovator by even trying a glass stylus. How did you make such a thing?
By accident at first, LOL. A mirror had broken and when I was picking up the pieces I noticed one was a perfect 90* right angle so while my hot glue gun was warming up, I tested it across the clear centre of a CD and noticed it embossed not scratch or etch. Many things we use in the world today had their origins from good accidents.
I did discover, however, the tip was extremely fragile and did not like sudden pressure of being let down on the disc. I have replaced it more than 10 times until I found a surgical steel razor at right angle ( ... l ... to ... \/ ... ) was close to reproducing that result and far less fragile.
Ha! Keep at it. Accidents are the best way to discover.
http://www.ebay.pl/itm/AD633AN-Manu-AD-Encapsulation-DIP8-Low-Cost-Analog-Multiplier-/130835546083?pt=LH_DefaultDomain_0&hash=item1e7667ffe3#ht_3268wt_952
http://www.ebay.pl/itm/1ps-MC1494L-IC-MC1494-Motorola-/320759287896?pt=LH_DefaultDomain_0&hash=item4aaebe5058#ht_3251wt_1249
NEUMANN SCHEMATIC http://www.ebay.pl/itm/NEUMANN-VMS-RECORD-LATHE-OPERATION-SERVICE-MANUAL-SET-/161000912571?pt=US_Other_Pro_Audio&hash=item257c66f6bb#ht_3458wt_1186 then you will understand into what you stepped
