I'm trying to understand the feedback in a head.
Would,a piezo disc work instead of the secondary winding?
Makes sense?
EmAtChapterV wrote:I've asked about this as regards a Fairchild 541A head. (Between the damping material and the armature.) The consensus seems to be that something with such low current would need its leads to be very well shielded to avoid inductance from the drive coil. It would need to be a very small piezo element too, about 10 x 10 millimeters.
Great explanation!opcode66 wrote:Without a second set of coils in your cutterhead you can't use feedback.
One set of coils are the drive coils. Any cutterhead including homebrews have one or two drive coils (mono or stereo head).
With an additional coil per channel you can then get feedback. Literally, the drive coil gets voltage and starts moving in the presence of the fixed pole magnet. The feedback coil is attached to the same moving part as the drive coil. The feedback coil has a very small voltage induced within it by being moved in the presence of a fixed pole magnet (just like in a phono cartidge).
So, the feedback coil will create a small voltage used to check the actual response of the cutterhead given the drive voltage. At points of physical resonance, the drive voltage can be lowered to assure flat response. This involves a preamp circuit where the feedback voltage is negatively summed with the drive when necessary to avoid resonance.
Could possibly a phono cartridge be used for that?opcode66 wrote:Yes, and the amount is controlled by a potentiometer. Therefore you can tune in a certain amount of feedback via calibration. On a Neumann rack we do -9db of feedback.
I've done some experimentation using a ceramic stereo pickup coupled to my DIY head for feedback. It is indeed real-time and does work. But there are issues. At first glance, it would look to b e good idea. They have very high output voltage as compared with a magnetic pickup. But, the downside is that they are also very high impedance devices, so you have to take care to avoid pickup from the drive coils. If the cross talk from the head drive is greater than the feedback signal, you are out of luck. A coil based feedback approach also has to deal with this too. If you couple the piezo such that it defects as a cantiliever (a stereo pickup would work this way), it is a amplitude sensing device. If you mount piezo disks to the torque tube they would function as an accelerometer. Closing the loop as a position servo is a much easier than based on acceleration. But I'm sure it could be done with some thought. The effect of the element on the open loop response of the system would have to be taken into account (add moving mass and/or stiffness). Also, you would have to make sure that the sensing is really responding to the stylus motion at high frequencies (no decoupling). If you have some experience with feedback systems, you should be able to cobble something up an and make some open loop measurements before closing the loop.Babooino wrote:Cool , has someone experimented something like that ?
I'm still not convinced why a piezo disc glued to the torque tube could not be used as feedback...
I use a piezo disc in my diy plate reverb with very good results.
markrob wrote:I've done some experimentation using a ceramic stereo pickup coupled to my DIY head for feedback. It is indeed real-time and does work. But there are issues. At first glance, it would look to b e good idea. They have very high output voltage as compared with a magnetic pickup. But, the downside is that they are also very high impedance devices, so you have to take care to avoid pickup from the drive coils. If the cross talk from the head drive is greater than the feedback signal, you are out of luck. A coil based feedback approach also has to deal with this too. If you couple the piezo such that it defects as a cantiliever (a stereo pickup would work this way), it is a amplitude sensing device. If you mount piezo disks to the torque tube they would function as an accelerometer. Closing the loop as a position servo is a much easier than based on acceleration. But I'm sure it could be done with some thought. The effect of the element on the open loop response of the system would have to be taken into account (add moving mass and/or stiffness). Also, you would have to make sure that the sensing is really responding to the stylus motion at high frequencies (no decoupling). If you have some experience with feedback systems, you should be able to cobble something up an and make some open loop measurements before closing the loop.Babooino wrote:Cool , has someone experimented something like that ?
