Too Much Stereo
DjMikiRia
Too Much Stereo
Post: # 27217Unread post DjMikiRia
Mon Sep 23, 2013 7:07 am
I have recently changed my cutter head arm assembly and am using new tiny tweeters as my mechanical source to move the stylus. I also use a surgical steal razor broken at exactly 45* (left/right). The problem arises on playback. There is too much stereo and I can not hear vocals over music.
Can anyone advise me please on what I can do to eliminate this please?
Fela Borbone
Re: Too Much Stereo
Post: # 27243Unread post Fela Borbone
Tue Sep 24, 2013 1:02 pm
Hello!
Maybe one of the channels is inverted? When a mono signal is present one speaker should "pull" while the other "push".Vocals are usually panned at the centre, so this can be the reason.
Hope this helps!
Babooino
Re: Too Much Stereo
Post: # 27247Unread post Babooino
Tue Sep 24, 2013 3:45 pm
A channel out of phase! Maybe on the playback system? Try to invert one of the playback speakers...
EmAtChapterV
Re: Too Much Stereo
Post: # 27248Unread post EmAtChapterV
Tue Sep 24, 2013 4:20 pm
I also wonder if something is restricting the lateral motion of the cutting stylus while leaving the vertical motion relatively unrestricted. What do the excursions in the cut groove look like?
