turntable bearing
ROLANDJAYS
turntable bearing
Post: # 34468Unread post ROLANDJAYS
Thu Apr 09, 2015 11:38 pm
I have been experimenting with turntable bearings.
I have built a turntable with 1 ball bearing in the middle like most standard turntables and i have another model with a roller bearing( size 50mm diam, 16mm thick )
My question is are there any other turntables with different types of bearings than these two?
dimi751
Re: turntable bearing
Post: # 34470Unread post dimi751
Fri Apr 10, 2015 12:10 am
Hmm good question..I only know the technics sl 1210 has 1 bearing at the bottom I'm not sure of other company's designs, anything on google searches ?
dimi751
Post: # 34471Unread post dimi751
Fri Apr 10, 2015 12:13 am
You probably know this already but here's the link
http://www.mikenewaudio.com/
Dimi
ROLANDJAYS
Post: # 34473Unread post ROLANDJAYS
Fri Apr 10, 2015 12:46 am
I have seen these before but haven't thought of using them.
.002" tir is too much when you measure 6 inches away
.1 degree of an angle will generate over .01" runout at 6" away
I already tried the taper method, it works...
Sillitoe
Post: # 34475Unread post Sillitoe
Fri Apr 10, 2015 4:45 am
Yeah I'm using a tapered roller bearing in my next build.
People have used Maglev bearings and air bearings for some high end stuff... I don't know much about it.
ROLANDJAYS
Post: # 34485Unread post ROLANDJAYS
Fri Apr 10, 2015 10:42 pm
I built a magnetic levitation bearing, but it didn't give as good a result as I thought. it would have needed much more work to be good enough.
the air bearing idea is good too, but I don't like the fact that you would have to have an air compressor somewhere making all that noise and vibration.
Sillitoe
Post: # 34487Unread post Sillitoe
Fri Apr 10, 2015 10:54 pm
Yeah, I was looking at this air bearing system that also included vacuum for the disk. Pretty interesting.
http://adanalog.com/index.php?page=shop.product_details&category_id=15&flypage=shop.flypage&product_id=145&option=com_virtuemart&Itemid=35&vmcchk=1&Itemid=35
ROLANDJAYS
Post: # 34491Unread post ROLANDJAYS
Sat Apr 11, 2015 12:28 am
that looks pretty fancy, but what I really want to know are specs.
I doo like the bldc motor though, 900 isn't that bad..
but again , no specs , must contact, these are for playback turntables too...
Sillitoe
Post: # 34492Unread post Sillitoe
Sat Apr 11, 2015 2:52 am
Yes only for playback tables, imagine how much air you'd need to pump to support a Lyrec platter!
As for many audiophile products no specs are listed, instead claims of "best" and "highest performance" are given. :lol:
I just found it while researching possible designs to copy haha.
