Sillitoe Lathes
Sillitoe
Re: SP10MKII Lathe
Post: # 34566Unread post Sillitoe
Wed Apr 15, 2015 1:25 am
I plan to sell custom built lathes in the future (once I've shown my systems fully working), no heads, just mechanics and electronics etc. If you don't find a suitable product then I can supply to you...
James
Bahndahn
Re: SP10MKII Lathe
Post: # 34576Unread post Bahndahn
Wed Apr 15, 2015 12:59 pm
I'm confident your future customers will be very happy with your work, your machines are very aesthetically pleasing, presumably functionally proficient as well!
I'm itching to see photos of your other builds, please post some if you wish, I think its safe to say we all would love to see them!!
Sillitoe
Sillitoe Studio Lathe
Post: # 34585Unread post Sillitoe
Thu Apr 16, 2015 1:25 pm
Doesn't look like much yet but here's another lathe I'm building using more parts from two grand format printers that I was lucky enough to acquire.
In its current state it weighs around 60kg and is 700mm long.
It has a brushless dc motor and lead screw setup mounted on the back.
It has a direct drive Baldor BSM90B- 3150AA brushless AC servo motor for the platter.
I'm waiting on some rubber vibration isolators to put in between the motor and shaft spacer.
The shaft that you can see in the photo is just there for reference and will be replaced with another shaft/ sub platter. It is attached to the motor with a flexible jaw coupling.
You can just see the edge of the tapered roller bearing at the base of the shaft (this is what the sub platter will sit on).
The suspension box is pretty hefty, haha.
Still working on the arm.
I will put my meters, electrics and controls into that stainless steel chassis at the right-front of the lathe.
I'm still looking into a few things, 16 inch vacuum platter (weighing around 15-18kg) and fluid coupling/ torque converter to dampen any vibrations.
I will probably have to go through a few variations of sub platters to accommodate different vibration dampers...
If you have one spare I'm chasing a NOS Lyrec or Neumann platter. :lol:
dimi751
Re: Sillitoe Studio Lathe
Post: # 34591Unread post dimi751
Fri Apr 17, 2015 5:13 am
Wow sillitoe you are very talented my friend good job This look very robust which motor use for the platter ?
Sillitoe
Post: # 34592Unread post Sillitoe
Fri Apr 17, 2015 5:32 am
Cheers dimi! The platter motor is the black thing that's hanging out off the side of the bench with the wires coming out of it.
It's one of these, very powerful.
Sillitoe
Post: # 34593Unread post Sillitoe
Fri Apr 17, 2015 6:10 am
Motor specs (the middle one)
BSM90B375AA-to-BSM90B3250AA.pdf
dimi751
Post: # 34636Unread post dimi751
Sun Apr 19, 2015 5:37 pm
Thankyou ! :D
Sillitoe
Post: # 34735Unread post Sillitoe
Sun Apr 26, 2015 5:04 am
Carriage with the arm starting to take shape.
The motor is now mounted with rubber vibration isolator fixings and there is absolutely no (perceived) vibration on the lathe or bench.
dimi751
Post: # 34738Unread post dimi751
Sun Apr 26, 2015 6:55 pm
Wow looks great nice progress :D
Sillitoe
Re: Sillitoe Lathes
Post: # 35256Unread post Sillitoe
Tue May 26, 2015 9:52 am
I received Caruso 133 today, thanks Flo!!!
It's sitting on one of two boards that will become high powered LM3886TF mono blocks.
The other thing is a stage for the microscope.
I've been getting lots of positive feedback and interest in the SP10 lathes that I'm planning to sell.
Thank you everyone, it is very motivational :D
I've given myself a deadline of 6 months to be ready to start offering systems.
I can't give a realistic idea of price yet, I'm still adding to and refining the lathe design.
I'm working on lots of things including...
Much simpler chassis design to enable the user to easily mount their TT.
Bolt-on 14 inch vacuum platter for the SP10.
Pitch control, switchable between analog and software (pwm knob and Ableton/ arduino).
(I wonder how many styli I'm going to break while sorting out the depth servo haha).
Control panel with head position marker.
Microscope slide/ vacuum arm for platter.
Tonearm. I'll probably go for the 12" Jelco as used by Opcode66.
I'm also looking into using these motors as they're low profile, have loads of torque and are very precise. http://www.nsk.com/products/precisionmachine/megatorque/#tab2
I need to build the amps, preamps, mount for the head etc before I show my current system running but that should be fairly soon.
James
analoghifi
Re: Sillitoe Lathes
Post: # 35257Unread post analoghifi
Tue May 26, 2015 10:26 am
I'm really excited to see this lathe come to life.
really nice to see how this has come along well.
dimi751
Re: Sillitoe Lathes
Post: # 35271Unread post dimi751
Wed May 27, 2015 12:21 am
Good for you Sillitoe , great to see creators of lathe products to the market
Very exiting stuff ! I love the Caruso head very nice product
Sillitoe
Re: Sillitoe Lathes
Post: # 35795Unread post Sillitoe
Wed Jul 01, 2015 1:05 am
Little update...
I've found reliable sources for nearly every part of the production models of the SP10 lathe.
Here is a link to a good source of SP10s (among other goodies) if anyone is interested. http://www.hifido.co.jp/?lang=E&genre=0301&keyword=&arrival=10&limit=10&price=0
Videos coming soon :D
James
dimi751
Re: Sillitoe Lathes
Post: # 35804Unread post dimi751
Wed Jul 01, 2015 6:05 pm
Thanks Sillitoe, far out a lot of good stuff on this website pricing is pretty good too.
symatic
Re: Sillitoe Lathes
Post: # 35818Unread post symatic
Thu Jul 02, 2015 9:31 am
awesome project! looks nice!
Sillitoe
Re: Sillitoe Lathes
Post: # 36655Unread post Sillitoe
Wed Aug 12, 2015 1:18 pm
Here's a short video of the auto head drop and lift in my new head suspension design.
It will be much prettier soon!
The head is mounted via a locking torque hinge for easy angle adjustment.
The wooden part will be replaced with a nice aluminium bar with a heavy duty torque hinge built in, it will be very solid.
I haven't tightened the bush up too much yet but it all works fine for this demonstration.
The air dashpot allows for precision adjustment and dampens the bounce from the spring.
I haven't mounted the depth servo yet.
The rc plane retract is fairly loud but I can't feel any vibration from it in the whole assembly... Silent lead in and out grooves should remain silent... We shall see!
In the video I'm using a potentiometer to lower and lift the head, you can switch it to be automated it in the same way as my pitch control via the DAW, this will make locked grooves (and locked groove records) very easy.
Lots more to come.
Cheers James. :D
Re: Sillitoe Lathes
Post: # 36657Unread post opcode66
Wed Aug 12, 2015 2:11 pm
You may want to work on smoothing out the lowering of the head. If you come down too hard you will chip your stylus. That is very painful to the pocketbook when working in diamond.
FYI, on a Neumann suspension, this is performed entirely with a servo that a pivoting front panel is connected to. The cutterhead connects to the swiveling panel.
The Shank
Re: Sillitoe Lathes
Post: # 36660Unread post The Shank
Wed Aug 12, 2015 3:46 pm
opcode66 wrote:That is very painful to the pocketbook when working in diamond.
8)
I'll just be leaving now :))
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
dimi751
Re: Sillitoe Lathes
Post: # 36667Unread post dimi751
Wed Aug 12, 2015 6:59 pm
Hi Sillitoe
Nice work ! Is this lathe system fully automatic in the future ?
Sillitoe
Re: Sillitoe Lathes
Post: # 36668Unread post Sillitoe
Wed Aug 12, 2015 7:07 pm
Na she'll be right fellas! 8)
Haha, yes, there will be a concave ramp on the bar where the moving part of the retract unit contacts.
The moving part of the retract will loose contact with the bar at a later stage of the drop, this will smooth the drop.
The depth of the moving part of the retract is also finely adjustable. I'll find the sweet spot.
I can also lower the voltage that is going to the retract for slower movement.
Calibrating the depth servo is what really frightens me about ruining styli!
Got any oldies you don't need guys?
