rek o cut vacuum tube bracket
- ROLANDJAYS
Here is a simple vacuum tube bracket.
I have it coming over the top becaus. There isn't any room beneath the feed screw.
Has anyone else come up with a different way to position the vacuum on these machines ?
- Stevie342000
Re: rek o cut vacuum tube bracket
Has any one experimented with the MSS (BBC Type 5) method of swarf pick-up? Interesting it was your vacuum tube that made me think about it, as that is very similar in design to the MSS type.ROLANDJAYS wrote:Here is a simple vacuum tube bracket.
The BBC (MSS) method was to use a blower near the head and this forced thread to the centre where it was pick up by the vacuum system.
The idea behind it as far as I can tell is that it cut down the possibility of interference with the vacuum and the cutting stylus, cutting down on the possibility of introducing noise in to the cut disc.
As far as I can tell the whole system was one end or the other of whole system, which provided cooling, vacuum and blowing. Ambient temperatures in cutting discs is one the variables that can effect a cut or cutting, as well as increasing life time of products through cooling.
Did anyone else other than the BBC or MSS use blowing instead of suction at cutting stylus. The other point I think is that you do not need such a high level vacuum and it cuts down on the noise levels considerably, as you would need a smaller pump.
After all it must be simple to implement they both are either the input or the output end of the cooling system.
- Stevie342000
Forgot to add nice work, but at that distance blowing my be better than suction, as the distance from the stylus is much greater than normal.
Finally where did you get the tube from? If you did not purchase it how did you make it? I think it get how it is done and forming the flare at the end is not that difficult nor is the bend in the tube, it's the same as bending tubes in plumbing. The flare is done over a form, unless anyone else knows better this is how I see it.
- ROLANDJAYS
The tube was custom made . Very easy to make at home.
You need a tube flaring tool.
And a tube bending tool. And a hack saw
- Stevie342000
ROLANDJAYS wrote:The tube was custom made . Very easy to make at home.
I thought it was simple, I will consult the engineering oracle and autodidact - my father. It still looks very neat and it looks completely original. The actual mount looks simple to replicate as well. Good work!!!!!
- Fela Borbone
Hi! I built mine in alluminium and epoxi. The head mount is also custom and displaces the head to the left to allow more recording time in CD's. I actually don't use it as my experience in cutting ended after ruining stylus and some blanks before achieve good results.ROLANDJAYS wrote: Has anyone else come up with a different way to position the vacuum on these machines ?
- Fela Borbone
Other pic
- Fela Borbone
Pic pic pic
- ROLANDJAYS
that looks pretty good, it is very close so I bet It would work well.
the tube on the one In my picture was far away on accident, I was just mocking it up.
- EmAtChapterV
Here's how mine was set up back in the day - hand-bent copper tubing strapped to the counterspring arm with the minimum weight for a 2.5 mil groove set, then if I wanted a deeper groove I'd stack coins on the cutterhead beforehand. It was kind of rough and prone to clogs, but custom machining parts isn't my strong suit and it worked most of the time.
I had been investigating a method of running the suction tube from the back like a Neumann system, but that fell by the wayside when I put everything on hold due to cutterhead failure.
