Germany SX84 DMM 12 " vs diy systems cutter head 3 "
sakuszi
Post: # 40559Unread post sakuszi
Thu Feb 11, 2016 5:16 am
https://youtu.be/tnEwe74o7Yg
This is a new record DMM head Germany SX84 . I compare to my head diy width band acoustic level dynamics and distortion not linear. The quality of sound damage microphones on the camera. For two hours I put a recording by line input computer . :!:
sakuszi
Re: Germany SX84 DMM 12 " vs diy systems cutter head 3 "
Post: # 40561Unread post sakuszi
Thu Feb 11, 2016 7:39 am
https://youtu.be/Hc-uGHzsow8
SX84 Germany vs diy cutter head D -300 mm , CF - 942 mm 10kHz - 3dB , DIY cutter D -60 mm CF-188 mm 10kHz -3dB :?:
sakuszi
Post: # 40563Unread post sakuszi
Thu Feb 11, 2016 8:12 am
sakuszi wrote:https://youtu.be/tnEwe74o7Yg
SX84 DMM vs diy head https://www.youtube.com/watch?v=8t8pbDP7H7o&feature=youtu.be 8)
Thelurker
Post: # 40597Unread post Thelurker
Fri Feb 12, 2016 2:10 pm
Good work man!
sakuszi
Post: # 40598Unread post sakuszi
Fri Feb 12, 2016 4:29 pm
Thelurker wrote:Good work man!
thanks
sakuszi
Post: # 40666Unread post sakuszi
Mon Feb 15, 2016 3:37 am
saku record lathe 4 https://youtu.be/HhFhaE6WE3c as will now be to record?
https://www.youtube.com/watch?v=8t8pbDP ... e=youtu.be lathe 3
Gridlock
Post: # 40667Unread post Gridlock
Mon Feb 15, 2016 3:53 am
My wife thinks i'm nuts for doing stuff like this. Playing with her sewing machine as an overhead. Really great shape and lever action needle dropper.
Gridlock
Post: # 40670Unread post Gridlock
Mon Feb 15, 2016 5:34 am
sakuszi
Post: # 40691Unread post sakuszi
Tue Feb 16, 2016 7:43 am
record STEREO 250mm 20Hz - 15000 Hz 0dB 1000Hz https://youtu.be/GEarheLts1Q :mrgreen: 8) :roll: :|
Questions? :?: :mrgreen: :roll: :) :|
sakuszi
Post: # 40693Unread post sakuszi
Tue Feb 16, 2016 8:54 am
TEST probe cut record , reproduction full video https://youtu.be/FbTYheeyfn8
Big Al
Post: # 40709Unread post Big Al
Tue Feb 16, 2016 7:41 pm
Great work!
What type of blank / cutting stylus are you using?
sakuszi
Post: # 40711Unread post sakuszi
Tue Feb 16, 2016 11:26 pm
thanks
I will now modest ... I know that it is well recorded, have a comparison ....
It is not easy to get these discs from Vestax Harmodisc to vrx2000 and perfected the knife in his hands, the blade is a needle Chinese steel chromed 80 - 90 degree angle. You can not go into too deeply with a knife, because can hear distortion, a good groove to micro groove 25 - 30 micron. Relax, it was the first groove 250 mm in a few minutes. I have a question, how to learn properly record vinyl records, if I was cheating myself?
