- shaolin disciple
12" transparent red color lathe records (wanted)
am looking to do a one of a kind record on a 12" lathe record I need this to play on all record player and be very good quality on red transparent clear red record the reason why and writing is am not having trouble finding places to do one 12" copy only in black or clear it will be around any where from 10-16 min per side am looking to spend the most $50 for one copy please hit me up on here if you can do this or know of a place thanks
- shaolin disciple
Re: 12" transparent red color lathe records (wanted)
I did not think it would be that hard to find some one to do a some clear red color records you can easily find them in 7" but not in 12" I don't think any one does these in red when it comes to lathe records I guess am going to have to go with just regular clear record
peace
peace
- petermontg
Why does it have to be red?
The simple fact it's a lot of hassle for just one record.
Having to order a sheet of red PVC for just one record is a waste of money.
Not to mention making it into a cutable sandwich.
The work involved is not cost effective from a cutters side of things.
If you order more 5/10 units am sure you will find someone to help you with your project.
Hope it doesn't discourage you on your search.
Best
Peter
Best
Peter
Peter Montgomery
+353(0)894926271
+353(0)894926271
You can ask Tim from Timitus Records, he can do red colored discs ala picture disc. The other colored results i saw were stunning.
Not sure if he can do one in this price range also the shipping will be expensive from DE->US, but check his webseite or facebook tell him Better12Bit send you. Good luck m8!
- shaolin disciple
@thecrates is this what your talking about http://www.vinyl-recording.de/english/ thanks
as you know I can do color tinted records (similar to picture disc style) as well
I call it color tint, it takes over the B side of the record, so only one side can have music
Hi I get 2 clear records I cut on both then I spray adhesive on 1 then spray red paint on then sandwich together ...I then put it through the laminator...don't put it together then cut the record. Use an old turntable when spraying be sure not get paint underneath we're you have cut the music.i use a 15 inch slipmatt .
Big love
Big love
