Hi all,
New to the forum and with a genuine interest in engineering outside of audio.
I've been looking into building a hobby lathe and would like to build my own vacuum platter. After looking at some vacuum platter pictures I can see there are varying designs. Of the ones I've seen there are split platters bolted/screwed together with grooves and holes drilled and a neoprene seal. However I have seen solid platters with grooves on the top - Do these work by the record sitting on the surface and creating a self seal to vacuum down?
Hopefully I've explained it well enough!
Thanks in advance
David
Vacuum Platter - How it works
