Lockdown turntable and lathe - a DIY project
A1beats
Re: Lockdown turntable and lathe - a DIY project
Post: # 64580Unread post A1beats
Fri Apr 12, 2024 7:00 pm
pentlandsound wrote:
Fri May 07, 2021 3:25 pm
The lathe, with the 'coin exciter' head mounted on its transport mechanism. When the head is fully lowered on to the disc, the stylus is at a very slight trailing angle (2 - 4 degrees from vertical).
Close-up of head transport. The counterweight is a collection of 'penny washers' held in place by two 6mm collars.
This post brings the 'project report' up to date (7 May) - I'll document my work henceforth in subsequent posts to this thread. Thanks to KNOP and Grooveguy in particular for their careful documentation of their own projects, and for making their findings public!
David
Hi David, Could u share info where u got the motor and linear pulley's and belt?
Thanks
Arnold
pentlandsound
Post: # 64601Unread post pentlandsound
Mon Apr 15, 2024 2:58 pm
Hi Arnold,
Here's some places where you might find what you require:
Pulleys: https://www.motionco.co.uk/grooved-pulley-20mm-round-belt-p-458.html
Depending on the diameter of the shafts of your linear rail and motor, you may need either or both of these:
https://www.motionco.co.uk/bore-reducer-bore-10mm-long-p-427.html
https://www.motionco.co.uk/bore-reducer-bore-10mm-long-p-430.html
Belts: https://www.ebay.co.uk/itm/394808486184
Endless 'O-rings' seem to work best. I don't think this was the exact listing on eBay, but it's very similar. You need a belt to fit your pulleys (3 mm CS), with the ID/OD (inner/outer diameter) chosen depending on how far apart your linear rail and motor are. Hint: don't make the belt too tight.
Motor: I have a Jugetek stepper, model 14HY0007-20B. I chose a NEMA-14 motor because it's fairly compact and sits more or less flush with the V-Slot rail, but there's no real reason that you couldn't use a NEMA-17 one - they are more common and easier to find.
Hope this helps!
David
Fattcamp
Post: # 64887Unread post Fattcamp
Tue May 21, 2024 7:38 pm
Hey guys,
I'm putting my Digikey order together and have a question on the capacitor values from the hand-drawn diagram (https://github.com/dn784533/lathe_guide/blob/main/LR_controller_circuit.png). Are these pF or nF? I doubt they are uF! These are for the 390 & 330 values on the bottom of the diagram:
Arnold: Sorry for the late reply. Had to take a break from the project for some family stuff. Appreciate Dave providing the links. I ended up getting the motionco stuff linked above and went with these O-rings on e-bay:https://www.ebay.ca/itm/335088185273?var=544315519791
Thanks guys,
Dave
pentlandsound
Post: # 64898Unread post pentlandsound
Thu May 23, 2024 3:59 pm
Hi Dave,
The 330 and 390 capacitors on the hand-drawn diagram are indeed uF. I had read somewhere that a 100 uF or so cap may be placed between 5V and GND to smooth out the supply to an Arduino; the 330 and 390 uFs were just two spare caps I happened to have that were near enough. Depending on your power supply and stepper motor, you might not need the capacitors. If memory serves, the Arduino in my system was being reset by spikes in the supply every time the stepper motor started up, and the capacitors were an attempt to get around this. It worked!
David
