Vacuum Pump Research
PMST
Re: Vacuum Pump Research
Post: # 60143Unread post PMST
Wed Feb 02, 2022 2:36 am
farmersplow wrote:
Mon Jan 31, 2022 1:56 pm
I plan to use an oil-free side channel compressor (radial compressor) for suction. Does anyone have experience with it? Can this work?
(Vacuum pumps with oil can produce oil fumes during purging - albeit small).
Example: https://www.doctor-san.eu/14-seitenkanalverdichter-filterboxen-filter
Greetings from Vienna
Thomas
That is the type of pump/vacuum i use, i use the model below for 2 VRs and works perfectly
https://www.ebay.co.uk/itm/313012959319
PMST
Post: # 60144Unread post PMST
Wed Feb 02, 2022 2:39 am
Any kind of side channel blower (if powerful enough) will work, self cooling and reliable
Angus McCarthy
Post: # 60161Unread post Angus McCarthy
Fri Feb 04, 2022 11:05 pm
A thought occurs, from my experience with pump organs and player pianos - has anyone experimented with the kind of multi-bellows vacuum pump used in several types of motorized player piano? I would imagine something like it would have been used in the early days of cutting for the same purpose.
Clunky and outdated? Very much so, but they are extremely quiet, and with a regulator should provide a steady flow. And, with the sad frequency that player pianos continue to be junked and gutted, it shouldn't be horribly difficult to source one.
Llisa
Post: # 62183Unread post Llisa
Sat Jan 21, 2023 11:40 am
Great Info, thank you!
How noisy are they?
Thomas
farmersplow
Post: # 62186Unread post farmersplow
Sat Jan 21, 2023 2:28 pm
It is not quiet. About like a powerful hoover. It bothers me when it runs continuously. To keep the noise within limits, a housing with sound insulation must be built. - Then the noise level is OK.
Post: # 62196Unread post tragwag
Mon Jan 23, 2023 5:16 pm
tragwag wrote:
Wed Nov 17, 2021 2:39 pm
I use this one, with an additional Variac
https://www.ebay.com/itm/292864311937?hash=item443012c281:g:tf0AAOSwljVgrCyJ
the vacuum I use is intended for replacing the pump in player pianos, it's super small and quiet when run with a variac.
but basically an MDF box around one of those Ametek Lamb central vac type units.
