1:10 conical reamer for Neumann Stylus DIY
farmersplow
Post: # 59703Unread post farmersplow
Fri Nov 05, 2021 6:00 pm
I had the problem of finding a suitable reamer to drill the receptacle for a Neumann stylus into an aluminum or brass part. :roll:
The pitch of the cone is 1:20 (on each side). A reamer is then referred to as a taper as 1:10.
Sketch:
In my search I came across a huge number of reamers with a 1:50 taper.
But I could only find 1:10 from a diameter of 3mm (which is too big).
So I need a taper reamer with a pitch of 1:20 with a diameter of 0.8mm (0.0315inch) to at least 1.4mm (0.0552inch).
My inquiry to a tool manufacturer was answered with a cost of EUR 600 and a delivery time of 12 weeks. :evil:
Since I'm poor and impatient, I needed my own solution. :oops:
After all, all I need to do is drill into soft aluminum and it only needs to be 1.2mm to 1.35mm accurate for the stylus to stick. :idea:
I built this construction accordingly.
So I firmly mounted a Dremel in a bracket that I can adjust at an angle. An angle can easily be set: a deviation of one cm must be set at 20cm. (or 30cm with 1.5cm deviation or 40cm with 2cm deviation ...).
I mounted this construction on a simple 3D milling machine from Proxxon. The Dremel rotates the 2mm drill at about 10.000 rpm. The cutter rotates the grindstone at around 20.000 rpm.
The drill (Dremel) is moved back and forth along the X-axis. Only a small amount of material is removed due to the low feed rate in the Y direction. After five back and forth movements, everything is ready.
The 3D (manual) milling cutter costs about 230 euros
The Dremel costs 50 euros
The 2mm drill costs 1 euro.
I have saved EUR 319 :D
P.S .: It works Nice
greetings from Vienna
Thomas
dmills
Re: 1:10 conical reamer for Neumann Stylus DIY
Post: # 59755Unread post dmills
Mon Nov 15, 2021 8:33 am
I think you have just reinvented the cylindrical grinder, very cool.
Be careful about clean up, grinding dust is evil and if it gets into the ways will completely ruin any precision that Proxxon ever had.
Regards, Dan.
farmersplow
Post: # 59760Unread post farmersplow
Tue Nov 16, 2021 4:47 am
Thanks Dan for the tip!
I try to keep the sanding dust away from the machine as well as from my eyes, nostrils and other inevitable skin wounds.
In this way, the precision of Proxon and myself is largely retained.
greetings from Austria
Thomas
sifis1983
Post: # 59792Unread post sifis1983
Sat Nov 27, 2021 3:09 pm
It's really amazing that you make this with a reamer!
I just 3d print (in aluminum) a torque tube with 1.38mm hole and the 1:20 cone seems that fits well.
Don't test it yet, cause I'm building a new head for it.
What kind of aluminum tube do you use exactly?
check mine below:
evildrome
Post: # 59798Unread post evildrome
Sun Nov 28, 2021 5:10 am
Well done! That is a novel solution to a difficult problem.
Model engineers have the same problem reaming small tapered holes and what they do is to make a " D Bit Reamer ".
https://www.homemodelenginemachinist.com/threads/making-a-tapered-d-bit.23861/
It's usually done on a lathe but there seems no reason you couldn't just do what you did but instead, turn the plain end of the drill into the tapered element.
Then creating the flat would simply be a case of locking the Dremel so it doesn't turn, setting the table parallel & then grinding the flat.
Cheers,
Wilson.
Phinster
Post: # 59801Unread post Phinster
Sun Nov 28, 2021 11:01 am
Hi..you don't happen to make corundum styli with facets for Neumann's by any chance? All we have are Japanese 'Adamants' and they're expensive and not that brilliant.
Thanks for taking the time! Pete
farmersplow
Post: # 59803Unread post farmersplow
Sun Nov 28, 2021 6:14 pm
Unfortunately, no. That is far beyond my capabilities.
farmersplow
Post: # 59804Unread post farmersplow
Sun Nov 28, 2021 6:32 pm
check mine below:
Aren't you afraid that the stylus will only hold on the outer edge and that it has too little contact surface? I would fear that the stylus would then change the angle (10 °) as soon as (or after some time) the stylus gives way in the bore.
Please tell me your experiences with it.
I think it is possible to press such a small cone into aluminum just by pressure. But I decided on a reamer because I can then finalize the diameter more precisely.
I don't have an aluminum tube directly. More like an aluminum stump. I then drill a 1mm hole (at an angle) into it - that is then rubbed off.
Nice greetings from Vienna
Thomas
farmersplow
Post: # 59805Unread post farmersplow
Sun Nov 28, 2021 6:38 pm
Here a picture with Stylus
Thomas
evildrome
Post: # 66643Unread post evildrome
Tue Jan 14, 2025 10:05 am
"I think it is possible to press such a small cone into aluminum just by pressure."
That is an interesting idea.
You could through drill 1.2mm, make a press tool out of 1.5mm carbide rod (with a blunt end at say... just under 1.2mm) and tap the tapered rod in and then press it back out from the other side (1:20 is not a self relieving taper). A bit of vaseline or even heavy oil on the press tool would help.
You would get a very smooth hole and zero wear on the press tool.
Also, you could measure the length of the press tool, calculate how far exactly it needs to be driven in (2.11mm from your drawing) and make a press jig which has exactly that amount of movement needed.
farmersplow
Post: # 66649Unread post farmersplow
Tue Jan 14, 2025 11:18 am
In principle, pressing is easy. But especially difficult in this case! The bore is not perpendicular to the torsion tube but 7° from the right angle. You would therefore have to clamp the torsion tube at an angle of 7° and then apply pressure to the cone. Drilling is easier because less pressure is exerted on the tube. Of course, I pre-drill a hole with 1mm and I have marked the conical drill bit with paint to ensure the drilling depth.
Fluxter
Post: # 66724Unread post Fluxter
Mon Jan 27, 2025 5:56 am
Sketch:
Thomas
Very practical way to do it. I trained as an instrument maker and spent years looking down and working with a microscope and magnifying glass at tiny things where even breathing would destroy it so appreciate your attention to detail. We had to spend the first three years making our tools and perfecting them before we were allowed to work on anything. Your stunning lathe is inspiring progress on mine too. Thank you from Australia.
farmersplow
Post: # 66747Unread post farmersplow
Wed Jan 29, 2025 5:49 am
Thank you and good luck with your project! I would be delighted to read something about it soon.
P.S. As long as the smoke is still inside, everything is fine. :D
Thomas
Fluxter
Post: # 66752Unread post Fluxter
Wed Jan 29, 2025 9:31 pm
Thank you for sharing your inspiring work.
