Blanks of Unusual Thickness (BOUT)
Kat
Post: # 59709Unread post Kat
Sat Nov 06, 2021 10:03 pm
It’s the recycled postcard gal again. I’m giving up on my recordio restoration as I simply can’t get any working grooves despite replacing every tube, crystal and cap, so I guess it’s time to look to the future.
I have a general question. Would a 1/8” thick record be usable with Presto or similar lathes? Can adjustments be made to fit a thicker blank?
Kat
Re: Blanks of Unusual Thickness (BOUT)
Post: # 59712Unread post piaptk
Mon Nov 08, 2021 9:24 am
Yes, 1/8" is no problem, as long as you adjust the right side of the overhead so that the overhead is level across the face of the disc. You can also just take off the platter mat, which should get you close.
MEGAMIKE
Post: # 59717Unread post MEGAMIKE
Tue Nov 09, 2021 1:06 am
hi
I had a similar job where I was too scared to adjust (long time ago) the setup up so I cut 2 records A/B then glued them together with thick polystyrene in the middle then cut the edges off and bored out the hole and another job I did it with cardboard in between, that thick cardboard with that hard inner lining ..lots of fun..
Post: # 59769Unread post tragwag
Wed Nov 17, 2021 2:40 pm
yep same! the first time I ever bought my own plastic (back in 2012, woof) I bought 3/16" by accident. it worked fine!
and was hilarious when people bought my 3x thick records for my punk band
Kat
Post: # 59780Unread post Kat
Tue Nov 23, 2021 12:48 am
Interesting!!
3/16, huh? that’s thicker than an edison! Do you happen to have a picture?
