Recording question
This is a special section, perhaps temporary, to help our man Timmy1 with his efforts to assemble a working 8J10 Wilcox-Gay Recordette for experimental record cutting. The reasons for this will be explained shortly, but please do check in and help! He's a great guy with a worthy project.
Recording question
Unread postby timmy1 » Fri Jul 26, 2013 9:49 am
I got my cartridge back from gib and it works fine it plays nice. I am trying to record on cd does it matter which side and I took a 5-16 nut and drilled it out to fit the spindle and it fits right in the cd hole but the cd slips on the turntable.
timmy1
Re: Recording question
Unread postby opcode66 » Fri Jul 26, 2013 2:35 pm
Use tape to hold it in place on your platter. A couple of pieces at the edge of the disc.
Groove Graphics, VMS Halfnuts, MIDI Automation, 320 Diamondsi & Stereo Feedback Cutterheads Soon!
Cutterhead Repair: Recoiling, Rewiring, Cleaning, Cloning of Screws, Dampers & More.
www.DeepGroovesMastering.com
Blog: View Blog (2)
Unread postby tragwag » Mon Jul 29, 2013 2:20 pm
Im with todd, definitely use tape to hold it down.
also, when trying to cut grooves onto a CD, I've done this:
-you should be cutting the shiny side
-depending on your lathe, either face of the stylus might be useful
on my recordette I could get some results with the regular stylus face, and also with the back side.
this was because I couldn't change the angle of the cutting arm on the recordette.
on the 6N, I only use the back side of the stylus, and a backward tilt.
hope that helps!
at Audio Geography Studios, Tallahassee, FL USA
Blog: View Blog (1)
Unread postby timmy1 » Mon Jul 29, 2013 2:46 pm
tragwag wrote:Im with todd, definitely use tape to hold it down.
hope that helps!
I can't see the shin side which side do I cut on the side that goes down on the cd player?
timmy1
Unread postby opcode66 » Mon Jul 29, 2013 3:02 pm
Yes, the side that goes down in the cd player. What he meant was don't cut into the foil side.
Blog: View Blog (2)
Unread postby tragwag » Mon Jul 29, 2013 6:54 pm
ah, very sorry Timmy.
I forgot momentarily to whom I was posting.
Todd is correct.
let us know the results!
Blog: View Blog (1)
Unread postby timmy1 » Mon Jul 29, 2013 7:16 pm
tragwag wrote:ah, very sorry Timmy.
Todd is correct.
Thanks no problem
timmy1
Unread postby timmy1 » Tue Aug 06, 2013 3:31 pm
Todd is correct.
Thanks no problem
I put on the edge of the cd and turntable but it does not hold it good and I used electrical tape.
timmy1
Unread postby opcode66 » Tue Aug 06, 2013 4:11 pm
Electrical tape isn't very good. Maybe try some Gaff tape?
Blog: View Blog (2)
Unread postby timmy1 » Sat Aug 10, 2013 12:33 am
opcode66 wrote:Electrical tape isn't very good. Maybe try some Gaff tape?
If I put tape on the cd would it interfere in cutting
timmy1
Unread postby opcode66 » Sat Aug 10, 2013 12:14 pm
You only put pieces on the outer edge.
Blog: View Blog (2)
Unread postby timmy1 » Fri Jan 10, 2014 5:10 pm
I tried recording on a cd and it worked. I recorded from the radio but you can only play it back once or twice before it starts skipping. I am going some solo plates. does it matter which side you record on and you probably have to cut off the rim of the plate? thanks
timmy1
Unread postby Steve E. » Sat Jan 11, 2014 12:24 pm
Ah, so nice to get an update!!!!
Yes, absolutely, you have to cut the rim off the picnic plate, and cut or drill a hole in the middle.
I wonder why the CDs start skipping after a couple plays. I'm guessing the playback stylus wears out the grooves.
Steve E.
Site Admin
Blog: View Blog (14)
Unread postby timmy1 » Sat Jan 11, 2014 3:04 pm
Steve E. wrote:Ah, so nice to get an update!!!!
does it matter what side of the plate you cut on
timmy1
Unread postby timmy1 » Sat Jan 11, 2014 5:01 pm
I can record on a cd it is loud but when I go to play back with a new play back needle the arm moves across the cd you have to hold it back slightly.
timmy1
Unread postby Snakeheadfishlab » Fri Mar 14, 2014 9:47 am
Actually you want to drill a 9/32 hole for the center hole and I have had good luck with solo plates,they seem to be a better quality plastic,and cut on the eating side of the plate.
Snakeheadfishlab
Unread postby timmy1 » Thu Apr 09, 2015 7:28 pm
I decided to sell my recodette so I put it on ebay today. It has 3 speeds.
timmy1
Return to The Epic "Recordette" Project
Who is online
Users browsing this forum: No registered users and 1 guest
