PRESTO 6N / DISC TO DISC TRANSFER / FIRST TEST
THEVICTROLAGUY
Post: # 68686Unread post THEVICTROLAGUY
Wed Jan 07, 2026 1:58 pm
my first experiment directly copying a disc using a direct transfer. i have the turntable plugged into the mixer going direct to the lathe. the results are surprisingly good, obviously an audio file is the best way to cut a disc but i wanted to hear the results of a direct disc to disc transfer. it works, a really interesting experiment...
THEVICTROLAGUY@GMAIL.COM
https://youtu.be/JE1Y8Cm2wmM
farmersplow
Re: PRESTO 6N / DISC TO DISC TRANSFER / FIRST TEST
Post: # 68694Unread post farmersplow
Thu Jan 08, 2026 11:04 am
I love your constant experimentation. New materials, new media, new signal paths. Keep it up!
EmAtChapterV
Post: # 68699Unread post EmAtChapterV
Thu Jan 08, 2026 9:51 pm
Supposedly this is the way the first Beatles single in Canada was done - a needledrop of a UK pressing run straight to the lathe, no tape copy in between.
Personally I'd be worried about subsonic signals from record warps making things complicated. I'd probably put a filter in to roll off everything below 30 or 40 Hz.
