High quality lathe shots thread (troll pr0n)
powerstrip
Post: # 25806Unread post powerstrip
Thu Jun 06, 2013 10:05 am
Ok I figured I would start a thread with high quality lathe photography, not sure if it has been done here yet...
Freshly salvaged, you can almost smell it!...
I will link these in high-res in case any of you may want some new posters or wallpaper
And more to come!
EmAtChapterV
Re: High quality lathe shots thread (troll pr0n)
Post: # 25829Unread post EmAtChapterV
Fri Jun 07, 2013 3:41 am
How are these?
And yes, that cloth wiring... most of it got replaced on my lathe when I discovered parts of the insulation had worn completely through after sixty years of rubbing against stuff, and were it not for the oxidization on surface of the wire itself, the lathe carriage could potentially have been live with up to 100 volts AC. :shock:
Edit - And I realize I should have cleaned the burnt chip off the stylus in the first picture. It's like giving a nice happy smile for the camera for your prom picture and then finding out later you had a big piece of broccoli stuck in your teeth.
drdub
Post: # 25831Unread post drdub
Fri Jun 07, 2013 4:50 am
Our VMS66
satan spins vinyl
*** www.drdub.com ***
Post: # 25870Unread post tragwag
Sun Jun 09, 2013 7:29 pm
photos from when I obtained my 2nd 6N
photos of the 1st 6N
a short video featuring our Presto 6N:
http://vimeo.com/54470073
powerstrip
Post: # 26470Unread post powerstrip
Sun Jul 21, 2013 10:22 am
I have these in hi-res at www.pwrstrp.blogspot.com if you want them...HDR imaging, RCA cutterhead + 6N
