cutting at 45rpm for playback at 78rpm
Stowvinyl
Post: # 49634Unread post Stowvinyl
Sun Mar 11, 2018 4:27 pm
Just wondered if anyone has done anything like this cutting at 45rpm but slowing down audio so record will play back at 78rpm.
i have calculated i should slow down by 42.3076923077 %
Is this correct i dont have a 78rpm turntable to check and would like to cut a 78 to send as a gift to a friend.
Any help much apreciated.
SueDenim
Re: cutting at 45rpm for playback at 78rpm
Post: # 49652Unread post SueDenim
Mon Mar 12, 2018 4:05 pm
Hi Stowvinyl,
There are any number of different ways of doing this depending upon what your set up is and where in the world your record is to be played back in.
I'm not sure that your percentage is spot on though... I usually find it simpler to adjust the sample rate of the audio file in my DAW to make it play back slower.
I use these figures:
US (60Hz):
(44100 / 78.26) * 45 = 25358
(96000 / 78.26) * 45 = 55201
EU (50Hz):
(44100 / 77.922) * 45.113 = 25532
(96000 / 77.922) * 45.113 = 55579
EU (50Hz) for US market (60Hz):
(44100 / 78.26) * 45.113 = 25421
RATIOS (50Hz):
77.922 / 45.133 = 1.727
45.133 / 77.922 = 0.579
Does that make sense?
Stowvinyl
Post: # 49664Unread post Stowvinyl
Mon Mar 12, 2018 10:35 pm
Thanks for the info Sue Denim
im based in the uk and the record is for the USA, my Daw is Logic Pro and there does not seem a way to change sample rate, how do i get the correct percentage think i will have to use varispeed.
Thanks Again!
Stowvinyl
Post: # 49666Unread post Stowvinyl
Mon Mar 12, 2018 11:45 pm
does this percentage seem better? 42.104925438258775%
fredbissnette
Post: # 49865Unread post fredbissnette
Sat Mar 24, 2018 11:43 pm
audacity has a setting just for this
