My old lathe ..
Jim L.
My old lathe ..
Post: # 3507Unread post Jim L.
Thu Sep 25, 2008 4:19 pm
Just cut some lacquer after the Rek-O-Kut Challenger refurbish. The cutter head is RCA. The playback is with a GE "RPX" cartridge. All original stuff.
http://es.youtube.com/watch?v=DPIi33vQ5Bs
Regards,
Jim L.
There is no such thing as an old movie. Just great pictures you haven't seen yet.
cuttercollector
Post: # 3509Unread post cuttercollector
Fri Sep 26, 2008 2:28 am
NICE !
I can only hope mine does that well some day.
Was that off the playback amp direct to the video recorder?
Jim L.
Post: # 3510Unread post Jim L.
Fri Sep 26, 2008 11:25 am
I tapped into audio path at the volume control of the R-8A cutting/playback amplifier these things are fitted with right into into the camcorder's audio input. The later Challengers where fitted with GE VR-RPX magnetic cartridges for playback and the amps where redesigned to accommodate them. The RCA MI-4889 cutter head's voice coil was "smoked" and I had to wind a new one for it. The impedance may be off a bit so efficiency may suffer during recording. But, it does seem to work nevertheless. The disk blank used is an "AudioDisk" yellow and was cut with a DuoTone steel 3-mil cutting stylus.
Jim L.
Simon
Post: # 3602Unread post Simon
Thu Oct 16, 2008 10:29 am
Can you post it cutting youtube?
