Hi all, been cutting away merrily on a VR for about 6 months and have mostly been getting good results.
The frustrating part is the constant issues that seemingly come from nowhere.
I had a near flawless transcription from source to vinyl going and then out of the blue I can't cut above about -3 (45 rpm) without a puffy kind of distortion mostly on the fringes of the stereo image. I can only think that perhaps one side of the cutterhead is damaged. I can't trace it to any particular source issues, I believe my system is calibrated properly, I am using a new cutter stylus with no noise or defect. My source has not changed, I have tried different program material and all sorts of things. Driving me crazy but the T560 can do that.....
Also, anyone use low level heating with a new stylus? Souri has told me NO heating with a new stylus but I find the cuts have less pops and crackles and I get a better cut without the nighmare of the lamps guessing game.
Any ideas would be much appreciated!
Cam
Vinyl Recorder /T560 heating and noise
Re: Vinyl Recorder /T560 heating and noise
If anyone read this and was interested - issue was with playback system. Somehow the calibration of the turntable went out of whack so after resetting it now it is good to go.
Same thing happened to me....I freaked out....hahaha!!
