Says hewlett packard on it and some info about the tubes. Any where I can get a diagram or a manual on this type of thing ?
Should work fine.. you could always try plugging in a newer cables and then use a continuity tester before replacing the old cable but it should work.. you might even want to replace the jack.evilartform wrote:I also noticed the RCA cables that connect heads are pretty bad shape. So I had planned on salvaging a modern RCA cable to get better connection and sound but the older one
Seems longer am I imagining that ? Or will it even make a difference? For now I just repaired the old crusty cables
piaptk wrote:Im not sure where you are or how flexible your schedule is, but I'm having another lathe cut camp in Tucson in a couple weeks. It will give you all the background you need to realize where you are at with that machine and how to move forward.
http://piaptk.limitedrun.com/products/598237-lathe-cut-camp-6-oct-21-23-2017
