DIY build log
cosmO_O
DIY build log
Post: # 31986Unread post cosmO_O
Fri Oct 24, 2014 12:18 pm
Hi Guys!
It is my firts post to share my worklog, maybe it will inspire more people :)
That is my first acceptabe testcut with an HDD head mechanism and a BSR sapphire enbossed into a CD-R disk. Any suggestions, ideas are welcome! Thanks!
https://www.youtube.com/watch?v=eN9PXwC9-0c
Re: DIY build log
Post: # 31991Unread post markrob
Fri Oct 24, 2014 4:41 pm
Interesting cutterhead. Can you provide more info on the operation of it?
cosmO_O
Re: DIY build log
Post: # 32003Unread post cosmO_O
Sat Oct 25, 2014 11:14 am
Hi Mark!
The link below was the source of the idea. It was the third HDD I tried. :)
http://www.instructables.com/id/Using-a-hard-drive-to-cut-a-record/
recordboy
Re: DIY build log
Post: # 33056Unread post recordboy
Wed Jan 07, 2015 9:43 pm
Hi cosmO_O
That is a really nice rig you have made, very nice indeed...
Interesting link too...
Cheers,
recordboy
cosmO_O
Re: DIY build log
Post: # 36343Unread post cosmO_O
Fri Jul 31, 2015 10:19 am
Hi Fellow Trolls!
I have a plan to see my scavenged neumann platter spin. I try it make cheap to save money to a decent cutter head, so i put the whole bulid onto an HDD motor used as a precision bearing.
It works, no problem with the 15+ kg mass, spins for looong minutes. It will be a belt driven solution, like an old western electric turntabe/cutter.
Any ideas/solutions/anything for a cheap but acceptable bearing or any experience about HDD bearig??? Thanks for the answer PM-s! :)
Image Image
cosmO_O
Re: DIY build log
Post: # 36517Unread post cosmO_O
Sat Aug 08, 2015 2:07 pm
Next pahse, some print work. Thank you EpicenterBryan for the inspiration!!! 8)
Re: DIY build log
Post: # 36518Unread post opcode66
Sat Aug 08, 2015 3:18 pm
You should also check out my bladerunner thread. I've posted quite a lot of useful information and videos.
http://lathetrolls.com/viewtopic.php?f=15&t=5250
cosmO_O
Re: DIY build log
Post: # 36519Unread post cosmO_O
Sat Aug 08, 2015 3:34 pm
opcode66 wrote:You should also check out my bladerunner thread. I've posted quite a lot of useful information and videos.
Thanks Todd, i usually check your build log, (any logs, pictures, every intel) maybe my next project will be a full diy head with diy drivers 8) :wink:
cosmO_O
Re: DIY build log
Post: # 36909Unread post cosmO_O
Mon Aug 24, 2015 3:14 pm
Some progression... Myshank blank with wax and a diacustic styli. Introducing Jim Morrison featuring some rumble and surface noise :twisted:
Next time I'll use a diamond styli :)
Image Image
Ciuens
Re: DIY build log
Post: # 36913Unread post Ciuens
Mon Aug 24, 2015 6:48 pm
hello, congratulations on the project is going very well.
My project is very similar to yours, I'm actually in version 6 of my cutting head.
I have had good cuts, and good sound quality.
cosmO_O
Re: DIY build log
Post: # 40140Unread post cosmO_O
Sat Jan 30, 2016 12:28 pm
Hey!
It was a copyright issue, röyksopp feat Robyn example in the audio :/
Next time I'll use a free audio track :)
cosmO_O
Re: DIY build log
Post: # 41168Unread post cosmO_O
Tue Mar 08, 2016 4:20 pm
I could not stop, an another acetate disc destroyed. VR style tweeter head with diacustic styli, 3d printed cone and carbon pushrods, 230 LPI (!!!) iRIAA with a DBX 321s, no success :(
The left side gone while i shoot the video ... thanks for the reply :)
cosmO_O
Re: DIY build log
Post: # 44150Unread post cosmO_O
Wed Sep 28, 2016 1:06 pm
A little update to my little thread.
3D printed bobbins, remagnetizing, 4.5 meters of 0.2 mm diameter copper wire and some lacquer. TADA! (And a cup of Kefir :P )
Next project a 320 styl adaptor.
cosmO_O
Re: DIY build log
Post: # 46592Unread post cosmO_O
Tue Apr 04, 2017 12:21 pm
After a big break, i came back to the cutting. I almost finish my lathe, i bought a diamond and blanks from myshank, but i'm not sure about the cutterhead weight measure.
I use a jewel scale, at the same height as the surface of the blank. I set the weight, but its seems too light, its 15.6 grams I'm a little nervous, i don't want to destroy the sytlus with the first try. ANY suggestions???
Thank you guys!
cosmO_O
Re: DIY build log
Post: # 46685Unread post cosmO_O
Tue Apr 18, 2017 2:54 pm
Status update!
The digital jewel scale went total crazy because the D1 magnet. Every measurement went to negative sign, so i droped this solution. Next one will be a micrometer scale like myshank mentioned http://www.myshank.com/scale.jpg
OR Any other idea? Thank you guys! :idea:
