Calling VR users - Help using this tool?
cosmicslop
Post: # 51704Unread post cosmicslop
Sun Nov 11, 2018 3:58 pm
Hello all,
I have a VR, and I can't for the life of me remember the utilisation of this tool, see photo attached:
How exactly is it used in the calibration process? I vaguely recall from Souri's training day but my notes are blank on this except for a shitty drawing of the tool itself.
Cheers,
Henry
SueDenim
Re: Calling VR users - Help using this tool?
Post: # 51705Unread post SueDenim
Sun Nov 11, 2018 4:15 pm
It's to sit the cutting head on (upside down), so you can change the stylus more easily.
cosmicslop
Post: # 51706Unread post cosmicslop
Sun Nov 11, 2018 6:56 pm
SueDenim wrote:It's to sit the cutting head on (upside down), so you can change the stylus more easily.
Thank you for your response. That is helpful. It has no role in calibrating the cutterhead angle then?
audiosteam
Post: # 51710Unread post audiosteam
Mon Nov 12, 2018 6:00 am
No. it's for holding the head upside down under the microscope. For cutting head angle calibration use something rigid that you cut to the desired angle. Myshank sells some if you're not making your own.
cosmicslop
Post: # 51794Unread post cosmicslop
Thu Nov 22, 2018 12:44 am
Thank you
yano
Post: # 51795Unread post yano
Thu Nov 22, 2018 1:37 am
does Souri give this to VR?
audiosteam
Post: # 51796Unread post audiosteam
Thu Nov 22, 2018 5:32 am
Yes it's part of the bundle. A must have for the head as the tool for changing the stylus.
yano
Post: # 51798Unread post yano
Thu Nov 22, 2018 6:53 am
would anyone know exactly what the Souri's VR starter set contains?
Besides that :
Complete Mechanic
Stereo Cutter Head
Diamond Stylus
Lamp 220V 40W
19" Main Unit
Inclusive Regulated Power Supply
are there any little things? for example : record clamp, screwdriver, mono microscope or this the calibration tool ?
