Transparent blanks behaves differently when cutting
blackmoondivision
Post: # 56533Unread post blackmoondivision
Sat Aug 15, 2020 6:51 am
Hi Trolls,
hope you are well and healthy!
Issue: Found out a transparent blanks behaves differently when cutting on T560. This may apply to any cutting machine out there.
With black blanks from Souri I normally cut on 40 degrees, stylus heating set 10 to 20 degrees. all good
With black blanks from MyShanks I normally cut on 25 degrees, stylus heating set to around 10 degrees or slightly more. all good
Recently tried to cut transparent discs from Souri and MyShank but having same issues.
Noise floor is overall higher than with black blanks, but most noticeably first 10 mm of the cut. Middle section and end are within the limit, but still noisier than on black blanks. What's even worst, one every second or third blank the cut material is building up around stylus making cut even noisier.
Anybody experiencing similar or same issues with transparent blanks?
Greetings from Prague, Czech Republic!
trailerparkjesus
Re: Transparent blanks behaves differently when cutting
Post: # 56534Unread post trailerparkjesus
Sat Aug 15, 2020 9:51 am
I do find black blanks are quieter. Although, clear shouldn't be giving you a huge noise floor difference unless your stylus is coming to an end. Make sure to measure heat from outside of the blank and heat from outside, clears take forever to heat up.
blackmoondivision
Post: # 57364Unread post blackmoondivision
Sun Dec 20, 2020 9:06 am
Thanks for the tip. I actually measured temp. around 5cm from the edge, so there was around 5 degrees difference. Yes the transparents takes forever to heat.
nikc
Post: # 57973Unread post nikc
Sun Mar 07, 2021 4:27 am
Hi Sorry it been a while since you wrote this. I am having same trouble with clear blanks. I am getting swarf stuck to record and wondering if I am not measuring temp right. What do you mean by measuring heat from outside the blank
Thank you
Nik
Nik Clifford
Pearl Home Records
blackmoondivision
Post: # 57977Unread post blackmoondivision
Sun Mar 07, 2021 5:20 am
Measuring from outside means - point your temp measurement devise to 1 - 2 mm from the edge of the record, where you start cutting. you need the correct temp especially on the edge of the record. Right temp on the edge = no problems with clear blanks.
nikc
Post: # 57978Unread post nikc
Sun Mar 07, 2021 6:45 am
Hello
OK got it thanks for the advice.!
Nik
Nik Clifford
Pearl Home Records
nikc
Post: # 58957Unread post nikc
Sat Jul 17, 2021 1:54 am
Hi
Yes now my stylus is a bit older (not too old.maybe 40 hours) am getting floor noise with clear blanks and no noise with black blanks.
This is speculation but using the laser thermometer on clear blanks (myshank) its saying 26 degrees, but perhaps it is less than that. It could be getting the reading from the matt behind..( the laser on the thermometer is going through the clear blanks and bouncing off the matt behind.) . I wonder how I could test this?
Best
Nik
(Pearl Home Records)
Nik Clifford
Pearl Home Records
nikc
Post: # 58958Unread post nikc
Sat Jul 17, 2021 1:57 am
Ps I have been measuring on the edge. Though maybe not close enough
Nik Clifford
Pearl Home Records
