My best Gakken toy recordings (thanks Lathe Trolls)!
SquirrelMonkey
Post: # 58388Unread post SquirrelMonkey
Tue Apr 20, 2021 1:40 am
I've read many tips on this forum to make better recordings and I tried most them. It worked!
See the attachments for the results. If people have feedback I can learn from, please let me know.
Still have to try the microwave and ZIPPO fluid methods.
discosdecorte
Re: My best Gakken toy recordings (thanks Lathe Trolls)!
Post: # 58395Unread post discosdecorte
Tue Apr 20, 2021 5:44 pm
Amazing! Congrats! 🙌🏼
realtime
Post: # 58398Unread post realtime
Wed Apr 21, 2021 1:24 pm
Hi SquirrelMonkey!
That’s pretty impressive. :D
Did you make any mods to the recorder or was it a matter of fine tuning the recording process. I read that the Gakken has no equalisation. Did you pre-process the audio files to optimise the sound?
SquirrelMonkey
Post: # 58403Unread post SquirrelMonkey
Thu Apr 22, 2021 12:24 am
Hi SquirrelMonkey!
Yes I pre-processed the audio files. Also, Audacity has under "speed" A function to convert rpm. I converted my sound file from 78 rpm to 33 1/3 and I recorded that on the gakken in 33 1/3 RPM. I play it on a record player with 78 rpm. I used a blanQ blanc instead of the Gakken blancs. Soon I am going to try the Zippo fluid trick. Maybe it will make a difference.
concreteutopia
Post: # 61911Unread post concreteutopia
Thu Dec 08, 2022 11:24 am
Hi SquirrelMonkey!
I agree, this sounds pretty good. Did you emboss or cut on the Blanq's?
naloisio
Post: # 62162Unread post naloisio
Wed Jan 18, 2023 12:10 am
These sound amazing SquirrelMonkey! I've just received a handful of blanQ blanks and am hoping they provide this level of quality on the Gakken.
Do you mind sharing your process for getting such clean, noiseless recordings? I haven't been so lucky in my tests to get such a clean recording.
LennonG
Post: # 62230Unread post LennonG
Sun Jan 29, 2023 3:13 pm
That recording sounds amazing! Can you explain how you mastered your audio before recording with the Gakken record maker?
