Angulo Records lathes of Argentina....wah huh?
Distinct from the "Members Only" section about business disputes, this is a section for those sellers who have distinguished themselves by scamming multiple customers. AND for sellers who have ghosted customers during long delays. If you intend to start a thread here, you must check with Steve E. first -- this forum should only be a LAST RESORT.
Steve E.
Site Admin
Post: # 31258Unread post Steve E.
Sat Sep 06, 2014 1:11 pm
I am starting a thread because there's a surprising lack of information about this company: Angulo Records. They are based in Argentina.
We have one recent user, Miguel AKA sunkingrecords, who has one and is learning to use it.
http://angulorecords.com/
Apparently the company it is run by a guy named Raul. Is he not a member here?
There are a few threads that address the lathe, all by Miguel. Is it possible that the other users of the lathe are not on this site? Is it a language problem?
Steve E.
Site Admin
Re: Angulo Records lathes....wah huh?
Post: # 31259Unread post Steve E.
Sat Sep 06, 2014 1:17 pm
ANGULO RECORDING
R-E-D Serie Pro 2.0 (RED Serie Pro 2.0)
(link on facebook says "Edición limitada............USD$ 6.875")
https://www.facebook.com/AnguloRecords
Grabador fonografico
Modulador de ancho de surco
Control de temperatura por caída de tensión
Regulador de profundidad de corte
Reproductor USB auxiliar control digital
AUTOMATICA controlador programable de tiempos y espacio: inicio de disco, pista 1 a 10, espacio/tiempo10sg entre pistas, sierre de disco, posicionado de cabezal a punto inicial, retroceso, fin de disco elevador de cabezal con habilitador de caída
Modulador de ancho de onda analógico/digital (potencia/ frecuencia)
Direccionado de vector
Grabación sentido horario /antihorario
Vumetro de potencia
Entrada de potencia externa
Regulador de altura y Angulo de brazo porta cabeza
Regulador de Angulo de ataque
Cabezal articulado para cambio de diamantes de corte
Suctor de corte
Conmutador automática/manual
Peso total :50kg.
Medidas: 57x62cm.x 35cm de alto
Potencia:300WRMS estéreo
EQ RIAA INTEGRADO …
Cerebro controlador automático
Sistema de entrada USB PC AUX
*Tiempo de grabación 27 minutos* por lado en 12″
Steve E.
Site Admin
Re: Angulo Records lathes of Argentina....wah huh?
Post: # 31260Unread post Steve E.
Sat Sep 06, 2014 1:31 pm
Translation of the above:
Recorder phonograph
Groove width modulator
Temperature control by voltage drop
Cutting depth regulator
Player Auxiliary USB digital control
automatic digital programmable controller of time and space:
start of the disk, track 1 to 10,
space/time10sg between tracks,
Sierre disk,
positioned to head to the initial point,
reverse,
end of disk head lift with enabler
Width modulator analog / digital waveform ( power / frequency )
Recording vector clockwise /counter clockwise
VU meter power
Check external power
Height adjuster and holder arm angle head
Controller Attack Angle
Articulated head for changing cut diamonds
Cutting suctorial ("cutting sucking mouthparts" :D)
Switch automatic / manual
Total weight: 50kg .
Measurements: 35cm high 57x62cm.x
Power: 300WRMS stereo
RIAA EQ INTEGRATED ...
Brain automatic controller
USB PC System AUX input
* Recording time 27 minutes per side * 12 "
Steve E.
Site Admin
Post: # 31261Unread post Steve E.
Sat Sep 06, 2014 1:32 pm
Sistema Automatico
automatic system:
Steve E.
Site Admin
Post: # 31262Unread post Steve E.
Sat Sep 06, 2014 1:36 pm
DISCOS DE VINILO VIRGEN
VIRGIN VINYL RECORDS
Los discos vírgenes en su composición de un 60% de Poli-cloruro de vinilo con agregados de polímeros especiales para el proceso de corte.
Comúnmente muchos confunden el discos de acetato con los discos de vinilo y discos de vinilo virgen
Se recomienda estudiar el tema
Blank discs as constituted 60% of poly - vinyl chloride with added specialty polymers for the cutting process .
Commonly many confuse with acetate discs and vinyl discs virgin vinyl
It is recommended to study the issue
Steve E.
Site Admin
Post: # 31263Unread post Steve E.
Sat Sep 06, 2014 1:51 pm
sunkingrecords
Post: # 31265Unread post sunkingrecords
Sat Sep 06, 2014 2:07 pm
Hi Steve!
I can add that I don't know anybody else who has the machine.
I'm still learning, as you said. At the moment, I don't have the system fully installed (I lacked a proper turntable at first, working on that now, and also lacking the heat lamps and a good vacuum for the chip pickup), so I can't confirm good results on the machine, but mostly by my fault.
I have an on/off comunication with this guy Raul, because he is at the moment relocating to another country, but he has been helpful at first when I made the first attemps. For example, I haven't seen the last video where he explains the "automatization" controls (the part with the USB drive, which by the way only reads MP3 :( ).
I'm not sure if he knows about this forum.
About the virgin records, I don't like them too much, as they tend to warp easily and are very light. I can ship you a few if you or someone wants to try them. I could use a second opinion on the quality of the material.
Kind regards
Miguel
I choose not to run .-
Steve E.
Site Admin
Post: # 31269Unread post Steve E.
Sat Sep 06, 2014 3:58 pm
Thanks for the offer! Send them to someone else to test. I am not up and running enough at present to help.
I extended an invite to Raul today. He should be here.
SUNBEARS
Post: # 31271Unread post SUNBEARS
Sat Sep 06, 2014 4:47 pm
Love the design, but would have been easy enough to have included a vacuum system, not unlike Souri's VinylRecorder. Also, the torque will probably be an issue if you're going to be putting significant weight on the cutterhead / platter. Maybe not for 7", but definitely anything with a bigger diameter. However, looks like Raul included lots of great features. Love the automatic system. That's one thing I would like to have with my vinylrecorder. However, even tho VR is fully manual, I'm getting great results. Can't complain!!
Good luck, Miguel!! Beautiful looking machine!
ROLANDJAYS
Post: # 31277Unread post ROLANDJAYS
Sun Sep 07, 2014 12:35 am
I emailed him.... now we wait.
I wonder how much he charges, because argentina dollar is .12 of American dollar... mean 6500$ argentia = 775$ us....
Steve E.
Site Admin
Post: # 31299Unread post Steve E.
Mon Sep 08, 2014 10:10 am
It says specifically USD.
ROLANDJAYS
Post: # 31310Unread post ROLANDJAYS
Mon Sep 08, 2014 9:23 pm
he responded, gave out some fair prices.
he sells the whole unit , or just the cutter head or just the amp.
so that's cool for some of us that just need the head and amp.
email him to see for your selves.
Vice Fiori
Post: # 35095Unread post Vice Fiori
Mon May 18, 2015 1:42 pm
sunkingrecords wrote:Hi Steve!
I can add that I don't know anybody else who has the machine. I'm still learning, as you said. At the moment, I don't have the system fully installed ....
Hi miguel..
I know Im late, but think it's good make an up from this post..
I look this machines months ago, and I still interest...
I think buy maybe the version 2, or even the economic, only to test and see what this machines can offer...
Do you have some new results, almost 1 year after?
I dont know anyone who get this machines too, i hear some sounds, look'n great, but i think the better view is the point who really have one and tell us... Think you're the chosen one.. ahahah
angulorecords
Post: # 35717Unread post angulorecords
Fri Jun 26, 2015 7:24 pm
Raul: really had no idea of this, but I think I had good predispocicion with Miguel even travel to your city to help personally .
to show results with the machine
I'm here to clarify things and answer questions ,
They must agree not to speak ill of something that is not known
angulorecords
Post: # 35720Unread post angulorecords
Fri Jun 26, 2015 9:50 pm
A chemical that removes vinyl records and then re- record them an invention ANGLE RECORDS
https://www.youtube.com/watch?v=8tlnYvXVPkg
angulorecords
Post: # 35736Unread post angulorecords
Sat Jun 27, 2015 11:49 pm
Recording a recycled vinyl discs with chemical AS
https://www.youtube.com/watch?v=cMlJp9xUFGc
A former Christian music disc is erased with the chemical AS,
eliminating old regristros slots enabling new records , in this case registered ELECTRONIC MUSIC " TRANCE "
The Shank
Post: # 35738Unread post The Shank
Sun Jun 28, 2015 4:48 am
I would prefer hearing the recorded signal from/on this cutted blank, the original signal and the unmodulated groove :?
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Cutterheads - HeLiX23
Big Al
Post: # 35739Unread post Big Al
Sun Jun 28, 2015 5:34 am
Interesting!
So with this chemical you are able to strip away the top layer of a pressed record and then cut it?
And you are able to cut it with a Sapphire?
On the video the chip looks white or clear - is this a byproduct of the chemical used?
I would have though chip from a pressed black record would have been black no?
Please let us know more details and like The Shank said please make videos where we can hear more - a direct recording from the audio output of the turntable playing back the record - not from a camera mic if you can do it would be amazing!
Very interested to find out more, as someone who's likes to recycle, the prospect of recycling old records to be able to use for Lathe Cuts is VERY VERY APPEALING!
Thanks Raul!
uvoscillator
Post: # 35759Unread post uvoscillator
Mon Jun 29, 2015 5:56 am
Big Al wrote: So with this chemical you are able to strip away the top layer of a pressed record and then cut it?
I can suppose that record was just covered by that fluid "pvc-secret-formula" and old grooves still there ))
Best !
angulorecords
Post: # 35763Unread post angulorecords
Mon Jun 29, 2015 9:52 am
Thanks for the suggestions and I am always open to criticism contructivas
here a video with audio directly online
https://www.youtube.com/watch?v=dYleVQ2bnuA
