A fully automatic record cutting machine from the 80's in beautiful condition. This lathe cuts 7" inch blank records on 33 or 45 rpm.
Comes Including the original stylus, record clamp, three manuals (photocopied) and the original electrical cable.
With this machine you can control input levels of line or mic (mono) There is a compressor controlling the input level (Great for protecting your stylus). You can fine-tune the platter speed on both speeds. This unit can cut lacquers, PVC, and polycarbonate blanks, even CD's with the correct stylus. Comes in a beautiful suitcase. It's very compact and you can carry it with you anywhere and even start a mobile cutting booth.
This machine is working, platter and motor drive belts replaced to fresh ones. Power turns on, platter turns, lathe moves forward and backwards, input + VU meter works, cutter head receiving signal. Runs on 100W (not the American 110) which is the Japanese power rating, you will need a converter depending on where you are.
Asking $3000
- Black Parrot Music
Re: Rare Vanrock E-101 Vinyl Record cutting Lathe machine - AKA Atom A-101
Hello, where did you find belts?
- Steve E.
- Site Admin
Did anyone get scammed on this?
