7'' plastic inner adapter name
Stuff not covered by the other...Forii? whatever. General goofiness. (You should not post here unless you've been contributing elsewhere on this site.)
filtersweeper
Post: # 8845Unread post filtersweeper
Thu May 13, 2010 3:43 pm
Is there an actual name for those plastic things we pop in the center of a 7"?
This may be in the wrong place but I ddidn't know where else to put it.
Thanks
Post: # 8847Unread post Aussie0zborn
Thu May 13, 2010 6:24 pm
If it's the three-pronged design it's often called a "Spider". If it's a round hub like the one you get when you buy a Technics SL1200 turntable it's often called a "45rpm adapter". There may be other names for them too.
filtersweeper
Post: # 8848Unread post filtersweeper
Thu May 13, 2010 6:37 pm
Aussie0zborn wrote:If it's the three-pronged design it's often called a "Spider". If it's a round hub like the one you get when you buy a Technics SL1200 turntable it's often called a "45rpm adapter". There may be other names for them too.
Thanks friend.
subkontrabob
Post: # 8850Unread post subkontrabob
Fri May 14, 2010 2:40 am
in reggae lingo the aluminum ones (technics standard or dome shaped) are called "pucks"
........at least in my parts of Germany
cheers
Simon
Post: # 8851Unread post Simon
Fri May 14, 2010 3:48 am
In the UK we call them centres or 45 adaptors
Happy to learn something new.
diamone
Re: 7'' plastic inner adapter name
Post: # 27600Unread post diamone
Tue Nov 05, 2013 12:56 pm
I got corrected by a couple guys that said only the kind that you squeeze the edges to pop into the disc are called spiders because of the legs. The aluminum versions - both the press-ins and the weave-ins like a Webcor that warp the 45 into which you are sliding it are called `plates'. And - in the case of the Pfanstiehl aluminum style with the indentations around the edges - the wrapper says the same thing `45 RPM Centering Plates'.
