Caruso Prototype
- blacknwhite
- GrobbingThistle
yes.just some slight but important progress.
drivecoils under test now....
still install & redesign my workshop so at moment i can not work, as i was used to work buut it gets better every day....
and
this is quite off topic now
i was a little absorbet with other, also analog gear.hehe. big children.big toys...but feedback is also very important.
http://vimeo.com/channels/synkie
http://hackaday.com/2011/05/08/synkie-the-modular-synth-for-video/
http://blog.makezine.com/archive/2011/04/synkie-a-modular-open-source-analog-video-processor.html
and
- petermontg
- JuanPabloCuervo
What kind of Brass ?flozki wrote:right now i made 2 brass , 1 bronce, 1 aluminum and 1 plexi-glass headblocks.
what kind of Bronze ?
i mean:
recycled?
zinc % ? Lead? lead free? Tin % ? silver ? iron ? phosphor?
nickel ? silicon?
UNS number?
http://en.wikipedia.org/wiki/List_of_copper_alloys
- JuanPabloCuervo
Re: caruso outline. dimensions and drawings
flozki wrote:i had many requests about the exact dimensions of the head and also how to fix on a particular machine....
so here you find the blueprints of the caruso mainblock.
all necessary info is on it to find a solution to fix a caruso on your lathe.
this part wont change that much anymore. so you can prepare..
standard will be a (neumann) mount with 10mm (9.98mm exact) bar on the back of the head.
check.
or get the pdf:
http://www.floka.com/caruso/caruso_outer_dimensions.pdf
anyone has the .pdf ?flozki wrote:the bar is for fitting on a neumann lathe.ou can attach whatever you want.
use the drawings.... and check how to fit...
thanks.
It is a standard DSub socket on top (female if memory serves). That means you would buy a mail DSub and and wire the terminal pins appropriately so as to connect your amps' drive and feedback as well as the current for a heating wire.
I think its more of a clearance issue. Presto 6's have little room above the head..opcode66 wrote:It is a standard DSub socket on top (female if memory serves). That means you would buy a mail DSub and and wire the terminal pins appropriately so as to connect your amps' drive and feedback as well as the current for a heating wire.
I'd need to look at the drawing again, and whip out the ruler, maybe a right angle Dsub adapter will work. If not, I'd just lop off the "nose" on the presto w/ a hacksaw, it would be worth it i think..
If flo wires it with a little slack, the Dsub could be removed, and direct wire connections made.. Maybe an option from the factory?
generally its for reproduction.. but i like to play wif it sometimes..
I would assume dat u just need to NOT plug in the feedback wires.. Feedback is not exactly rocket science, almost.. it's like a bias current to keep tings in check..piaptk wrote:Would it be possible to use it without feedback? I still haven't exactly figured out what the hell feedback is and how to use it, despite reading all the threads about it.
If you have a Disk Recording Vol1 the red book then you can find there about feedback. Basically I don't think you will be able to use it without feedback, otherwise you can even damage the head. Feedback does a big job when used propertly and as I read here the Caruso will come with special preamp built along with the head. So you have to use it.
The concept is quite simple of feedback, and I have seen here some posted topics about it. There are some of explanations here....
Do
Do
Hi,piaptk wrote:Would it be possible to use it without feedback? I still haven't exactly figured out what the hell feedback is and how to use it, despite reading all the threads about it.
You might be able to, but you will need a very radical EQ to make that happen. The open loop response of a moving coil head is very different than the typical Presto, Audax, or Grampian you are used to. The open loop velocity response looks like an inverted V with the peak at the system resonance (in the 1-2Khz range). The slope is +6db/oct below the resonance and -6db/oct above. You will also have to deal with taming the resonance peak depending on how well damped it is. Finally, there will be some deviations from the textbook response that you will need to deal with. It is also likely, that the response will vary under actual load when cutting vs. on the bench. You can use the feedback coil to monitor the output of the head and develop the correct EQ. You must also add in the RIAA curve after the head is linearized to flat response vs. velocity. You may be able to combine the two and simplify the process.
If you don't have the tools to do this, I'd strongly urge you to purchase any preamp supplied by Flo as this will be designed to get the most out of the head. Hope this helps.
- TotalSonic
From my understanding based on what Flo said previously is he will be including with the head a PCB for the pre-amp along with schematics/parts list so that you could build the front end IRIAA encoder/feedback controller in your own chassis.piaptk wrote:Cool.. I would actually use this on my 8C, which has plenty of vertical clearance. Just couldn't figure out how to input the music, looking at the pics, but if he is selling a preamp that controls the feedback, I'd definitely pick that up as well.
Best regards,
Steve Berson
