Wanted: tonearm for VMS 70
prof msg
Post: # 23751Unread post prof msg
Thu Feb 28, 2013 4:40 pm
complete tonearm assembly or parts / bracket
SME or other
Re: Wanted: tonearm for VMS 70
Post: # 23758Unread post opcode66
Thu Feb 28, 2013 6:58 pm
I use one of these
http://www.ebay.com/itm/HI-END-JELCO-SA-750L-12-TONEARM-/300565515136
I also have an aluminum bracket made custom to my spec by a gentleman in China. Works fantastic with a high end cable and M97xE Shure Audiophile cart.
drdub
Post: # 23764Unread post drdub
Fri Mar 01, 2013 3:24 am
di you have any pictures of the bracket ?
that's on my to do list for years now...
cheers mex
satan spins vinyl
*** www.drdub.com ***
flozki
Post: # 23766Unread post flozki
Fri Mar 01, 2013 4:01 am
what do you mean with the aluminum bracket?
dont know what you mean. there might be something in flozki's stock...
drdub
Post: # 23767Unread post drdub
Fri Mar 01, 2013 4:11 am
usually the tonearm is mounted on the back.
we have it mounted on the fronside using an aluminum angle.
we have it this way, cause we cut 70% pvc dubs on the vms and we want to monitor the cut.
having the tonearm on the back is just a pain, and it interferes with the head cartridge.
for 2 years now we have this "temporary" fix (the nice german wird is "provisorium"), which works,
but is not accurate or anything else. all it does, is tho discover skips on the cut. the sound is.....
cheers
satan spins vinyl
