Record lathe for sale
Recently I finished to make my vinyl record lathe.
If someone would want such lathe, I can to make the same.
Short description:
Base – 450 × 200 × 100 mm granite stone.
Platter - Ø 340 mm, 50 mm thickness, aluminium with acrylic insert, with vacuum record suction,
weight 12 kg.
Belt drive type.
Motor – Maxon precision DC motor with optical encoder.
Motor controller – Maxon controller with possibility to controll motor speed and other parameters
by computer through USB link.
Manually adjustable pitch drive.
Adjustable stylus heating current.
Head suspension with adjustable counterweight and oil damper.
Verical cutting angle alignment with micrometer screw.
Head verical and horizontal movement by ball bearing slides.
Pitch drive by ball bearing slides too.
9.5‘ tonearm with RCA sockets.
Microscope.
Lathe weight – 50 kg.
Dimensions – l,w,h 800×400×450 mm.
Jonas.
Short description:
weight 12 kg.
Belt drive type.
Microscope.
Jonas.
Re: Record lathe for sale
Hello, price ? country ?
Not far from you Janos
guys are from Lithuania
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
- soeffingodly
Bummer, shipping to the states would probably cost me my unborn childs' soul. Ha.The Shank wrote:Not far from you Janosguys are from Lithuania
Lathe looks incredibly sexy though. Well done!
Some specifications about my lathe project.
Mechanically lathe works very good expect cutting head, which is incomplete.
Now I‘m working with head, make experiments, measurements, and tests in order to achieve good cutting results.
I can not present cut samples now because they are still not satisfied.
Because my work has succeeded, I want to make that lathe once more for sale.
And I presented this lathe wanting to find out whether it should demand in your society.
If anyone has good cutting had, I can make lathe without head, but with possibility to mounting your head.
Jonas.
Jonas.
Hello Jonas !Jonas wrote:Some specifications about my lathe project.
Jonas.
I would be interested.
should more detail, price, where are you from etc.
Regards Janos
- petermontg
I need a vacuum chuck.
Sent you a PM.
Peter
Sent you a PM.
Peter
Peter Montgomery
+353(0)894926271
+353(0)894926271
Wow. That is beautiful! Nice work!
Ok, now this looks good, congrats! Installing a flozki cuttin head would be interessting for sure!
fantastic!
PM me with price?
PM me with price?
hope it will work well with a Caruso head!
- planckepoch
Old thread I know - but if anyone could give me the specs of the motors?
damn first time i saw this. looks awesome!
