SOLD : Neumann Lathe for sale
andybee
Post: # 66301Unread post andybee
Fri Nov 29, 2024 4:34 am
AM32B with overhauled lyrec motor and frequency converter,
so works with any supply voltage.
Pitch system was updated with Pitch98 (inside the original Pitch Box)
Comes with SX-74, Minicut Preamp & brandnew power amp.
Nice system, have worked with this machine for many years, lot of fun to work with.
Brandnew vacuum pump & chip jar is also included.
For more details, please contact me at:
www.abmastering.com
instruction & training on request.
thanks for watching ;)
Caelan09
Re: Neumann Lathe for sale
Post: # 66317Unread post Caelan09
Sun Dec 01, 2024 11:44 am
Hi Steve,
Can you tell me where you are based ?
Also how much do you want for the Neumann ?
Thank you
CAELAN09
Caelan09
Post: # 66318Unread post Caelan09
Sun Dec 01, 2024 11:54 am
HI Andybee
I am after realising I called you Steve in my message adressed to you .My apologies .
Post: # 66319Unread post mossboss
Sun Dec 01, 2024 3:52 pm
If you hit the users name 9 times out of 10 you will find a location on their profile also if you look at the avatar on the right hand side it will also show a location
You certainly going up the scale fella, from Van Rock Hara Presto archaic systems you are on to Pro gear! Neumann!
I guess some want to hit the ground running
keep it up
"The Vinyl Truth"
leemichael
Post: # 66322Unread post leemichael
Mon Dec 02, 2024 4:23 am
keep it up
You don’t even need to do that! The seller has included his website address in the listing!!
andybee
Post: # 66324Unread post andybee
Mon Dec 02, 2024 5:24 am
the machine is located in germany, city: 84184 Tiefenbach, near the munich airport ;)
please contact me for price info.
Post: # 66327Unread post mossboss
Mon Dec 02, 2024 6:21 am
Maybe he start cutting inside out Used to be a thing,Ha, does it do that Andy?
"The Vinyl Truth"
andybee
Post: # 66345Unread post andybee
Wed Dec 04, 2024 3:51 am
no, the AM32 (also the VMS-70) cannot cut inside out, because the spindle feed
moves the carrige only in one direction (to the left side).
for those, who don´t know, the AM32 was the previous model of the VMS-70,
the mechanic is mostly the same.
What I like is, that you have manual switches in front of the machine, to
switch between 7"/10"/12" size for cutting, the tiny "automatic" switches in the back
of the VMS-70 are a constant source of problems, and not easy to maintain.
happy cutty cut 8)
Post: # 66348Unread post mossboss
Wed Dec 04, 2024 3:16 pm
Thanks Andy
Very informative to some I can say, to me is a well known fact
Yes the micros in the back do give some problems however they are extremely long lived and reliable, we just used the last of the 4 spares which are on the machine from new
Ours has cut a lot of sides let me say and for a machine made so long ago it's fantastic
By the way the "Start cutting inside out" meant to be a joke not a serious question
"The Vinyl Truth"
Phinster
Post: # 66352Unread post Phinster
Thu Dec 05, 2024 9:30 am
Used an AM 32 B ( the one with the cursor dial for LPI ) at CBS London in the early 70's You used the ammeter movement to estimate the pitch and you had to put a shim
on the end diameter stop lever when cutting a 7 inch ! It worked really well , but you had to look at the belts carefully, they used to slip...Pete
misjah
Post: # 66357Unread post misjah
Fri Dec 06, 2024 1:12 am
for those who are looking..we do inside out (even on DMM ;)) ...back to topic.
Post: # 66358Unread post mossboss
Fri Dec 06, 2024 6:03 am
Great stuff Inside out cuts, I have a box of 18" lacquers that I have kept in a safe environment for years, they are pristine and they will cut well, If any one wishes to cut a transcription lacquer inside out Ill pack and send them ONE on the proviso they upload whatever they put on it on a platform accessible to all and sundry
Any one here up for it? LMK
"The Vinyl Truth"
andybee
Post: # 66734Unread post andybee
Tue Jan 28, 2025 3:33 am
SOLD, there is another Scheffner Lathe with SC-99 for sale, interested? contact me ;)
