WTB 78 RPM FEEDSCREW FOR REK-O-KUT IMPERIAL II
jornibudich
Post: # 8178Unread post jornibudich
Wed Mar 17, 2010 2:41 am
Hey guys, let's give it a try here:
Got a Rek-o-kut imperial II but it came with the Microgroove Feedscrew and iddlers for 33 and 45 RPM only.
I need to get a 78 RPM complete feedscrew to mount it on my mechanism and a 78 iddler wheel if possible.
Also a question: If I cut with the 78 RPM feedscrew, I'll be able to make louder cuts? Based on my research the answer is YES.. but any other info will be more than welcome!
JORNI (Vancouver BC)
Joost
Re: WTB 78 RPM FEEDSCREW FOR REK-O-KUT IMPERIAL II
Post: # 8215Unread post Joost
Fri Mar 19, 2010 6:20 am
There's a rek-o-kut 78 wheel on ebay now: http://cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&item=290415137615
Cheers,
Joost
jornibudich wrote:Hey guys, let's give it a try here:
kgutzke
Post: # 8385Unread post kgutzke
Tue Mar 30, 2010 7:21 am
A courser pitch feedscrew ("78 feedscrew") will give you more groove spacing which in turn allows for larger groove excursions (loudness). Actual loudness will be determined (limited) by quality of your cutting head and amp system.
Simon
Post: # 8386Unread post Simon
Tue Mar 30, 2010 9:46 am
Are looking for the wheel or the leadscrew 12" or 16"
Happy to learn something new.
blacknwhite
Post: # 8390Unread post blacknwhite
Tue Mar 30, 2010 1:02 pm
kgutzke wrote:It isn't often an unused idler wheel gets offered so I suggest "grab it" while you can.
You're the seller, right?
#1. you should mention you're the seller, in that kind of post...
#2. ...Especially when you're prefacing your response to the original poster's question with a condescending "Obviously -- "...)
Please, remember, we want to GAIN more new people into the record-cutting hobby, not chase them away.
Thanks,
- Bob
kgutzke
Post: # 8429Unread post kgutzke
Fri Apr 02, 2010 11:21 am
Sorry if I seemed condescending or offended anyone. I was simply trying to clarify how a 78 course leadscrew can lead to louder cuts which becomes quite obvious (self evident) once explained and understood. I also removed my ad for the 78 idler wheel. Hopefully I'll learn better manners and communication skills in the future.
