Large Prototype Dynamic cutting head for sale (DIY / VR replacement ?) - Located NZ
Naboo
Post: # 63959Unread post Naboo
Mon Jan 15, 2024 12:32 am
Selling this dynamic head that was a version 2 prototype.
Tried to replicate a VR head (tyre-like surrounds etc...) and with the available parts here, this ending up making her a little chunky :mrgreen:
Worked great when tested on a VR, obviously with some additional set up to suit the size.
Needed a custom counterweight and EQ curve to be made (which I no longer have).
approx 550g
center of mounting post to bottom of diamond mount: 87mm
overall width: 130mm
drivers peak: 180w
drivers nominal: 120W
drivers impedance: 4ohm (more like 3.2ohm)
Cables will need terminating however suits your set up (currently the DIN plugs are for diamond heating).
The diamond mount will need a slight ream with a tapered drill or file to get the desired size for whichever shank you're using.
The diamond mount / torque tubes piece is the same as on LeeMichael's heads - This is because I made them :wink: :wink:
I have already sold one of these to someone currently still building their lathe, and another to someone who has cut some good masters with theirs.
This is the last one...
$480 NZD
+ freight from NZ to anywhere worldwide
This just covers my material costs.. but it's best someone out there may get good use from it, as I'm giving up the lathe life for now
Cheers :D
