Rek-o-Kut VD with crank and two feedscrews
apoklis
Post: # 67618Unread post apoklis
Sat Jun 07, 2025 4:04 pm
For sale: rekokut v deluxe with synchronous motor. Runs a 33 and 78 when using the idlers, but also belt ( Jed type) stepper motor drive, with set speeds of 33 45 78 and half speeds, all adjustable within 8 percent. It has a m5 ,16-inch overhead with a crank. It comes with two feedscrews 120 and 210 . It has an audax head that is flat at 12000 hz and come with an embossing stylis and 10 7inch blanks for practice or adjusting . It also has a rekokut micropoise 260 tonearm (the long one) with a at95 cartridge . There is a ¼ inch fused input connector to the head and two RCA output from the tone arm on the front and a 120 grounder plug connection on the back. This is in a homemade pine box. It is easy to use a great machine, but it is heave . I would guess 60 lb all together so shipping will be high. I will disassemble to protect during shipping if not local picked up or delivered. If we can work out a local pickup, Ill add some stuff and teach you how to use it. 4000 plus shipping.
apoklis
Re: Rek-o-Kut VD with crank and two feedscrews
Post: # 68326Unread post apoklis
Wed Oct 22, 2025 2:02 am
price drop 3500
trailerparkjesus
Post: # 68343Unread post trailerparkjesus
Fri Oct 31, 2025 11:36 am
Will you sell the feedscrew? I have this lathe but I'd like the 210 pitch
