Presto 85B Cutting Amp
ejemmons
Post: # 26644Unread post ejemmons
Mon Aug 05, 2013 6:47 pm
I have a Presto 85B Cutting amplifier in what appears to be very good condition. It's been in storage for about 50+ years, in a very dry place. My question is: should I try to sell it, and let someone restore it, or would it be preferable if I did that first? It looks to be of Military descent, and is really gorgeous to look at!
85BFront_IMG3672.jpg[/attachment[attachment=0]85BTop_IMG3673.jpg
RA-1574E amps.
Re: Presto 89B Cutting Amp
Post: # 26651Unread post tragwag
Tue Aug 06, 2013 11:48 am
I would say, take it to a local tube radio repair person to see what the cost is to get it re-capped, and generally restored.
I had great luck going that route with an presto 87A amp.
I'm no expert, but I would say your amp in good working condition might fetch $200-$400
If you're looking for more info on the unit, check out Alan Graves excellent presto site:
http://www.prestohistory.com
hope that helps!
ejemmons
Post: # 26656Unread post ejemmons
Tue Aug 06, 2013 12:57 pm
Thanks very much for the input, and the very cool Presto site! Guess it'll hit my bench after the 1547E's I'm restoring. Am mostly curious to see if anyone could get use from this amp. It's really an 85B, I goofed. I thought military due to the plug-in electrolytics (which I wish one could still get!), but it ought to be an easy recap as there aren't many in it.... Thanks again!
RA-1574E amps.
ejemmons
Post: # 26866Unread post ejemmons
Sun Aug 25, 2013 5:42 pm
Hi all,
With regard to the Presto 89B cutting amp, brainfart has occurred. It is actually an 85B.... It came from KGGM Albuquerque to me in about 1969, and I've had it ever since. I'm sorry for the goof!
Moderator's Note: No problem, your post has been edited to correct the model number.
RA-1574E amps.
MonsieurMatt
Post: # 28549Unread post MonsieurMatt
Thu Jan 16, 2014 3:55 am
Ej!
Id be really really interested in that amp! Please let me know if you want to sell it!
