Searching first Record Cutter in Germany up to 500€
budharpey
Post: # 29431Unread post budharpey
Wed Mar 26, 2014 11:49 am
Hello cutters!
I am searching for a first machine to cut/emboss with. The lathe lead screw mechanism and cutter head would be most important, I don't necessarily need a complete lathe with platter, etc. at the moment since I would use one of my record players for that. I am not afraid of crafting if needed (I am working on DIY lathe also in the meantime). I don't really expect to find something for up to 500€ since prices for useable cutters seem to be much much higher, but more money is not available at the moment. But anyway just in case somebody has any old more or less usable assembly in this price range to give away someday I would be more than glad to get a PM from you!
Best regards,
budharpey
budharpey
Re: Searching first Record Cutter in Germany up to 500€
Post: # 30472Unread post budharpey
Wed Jun 18, 2014 6:28 pm
update: still searching, if somebody knows something...
budharpey
Post: # 31622Unread post budharpey
Tue Sep 30, 2014 4:59 pm
update: still searching... :D
Post: # 31633Unread post piaptk
Tue Sep 30, 2014 11:39 pm
Unless you have a REALLY high torque turntable, you will get wow and flutter at best or the needle will stop the turntable at worst... especially if you want to emboss, because you need a lot of weight.
budharpey
Post: # 31644Unread post budharpey
Wed Oct 01, 2014 11:35 am
I have a strong relatively dual machine which does not have too much wow and flutter compared to other record players i have experimented. I want a first lathe mainly for experimenting and getting a feel for the thing before I will decide to spend more money on proper equipment.
I also am working on diy lathe projects on the way.. But I really would like to find and buy a Presto/Rekokut or similar like leadscrew mechnism for being able to cut. With my diy projects I have never been able to really try to cut so I only embossed so far...
Post: # 31647Unread post piaptk
Wed Oct 01, 2014 12:26 pm
I'm selling a federal recorder on eBay right now... Just the turntable and overhead mechanism.... I may be able to work a deal with you on a head if that machine was of interest...
http://m.ebay.com/itm?itemId=321538840007
buckettovsissors
Post: # 31800Unread post buckettovsissors
Tue Oct 14, 2014 4:37 am
Im in the same boat and looking for exact same thing, where in Germany are you?
budharpey
Post: # 31810Unread post budharpey
Tue Oct 14, 2014 4:52 pm
Yes, it's not an easy task to find a Presto-quality-like lathe here in Germany. Bavaria, near Passau. Where are you from?
budharpey
Post: # 44058Unread post budharpey
Tue Sep 20, 2016 9:36 pm
update: after a longer break my search again goes on... :D
