Ortofon DS522 Styli Wanted
Does anyone know who sells the styli for Ortofon DS522 cutter heads ?
Dimensions are 4mm length and .73-.75 mm diameter.
Is there a stylus from another head manufacturer that will fit those dimensions ?
Thanks
Nige, UK
Thanks
Nige, UK
- Cutterwoller
- jtransition
- Aussie_cutter
Re: Ortofon DS522 Styli Wanted
I'm also looking for Ortofon DS522 Styli. Please PM me if you can recommend a source.
Thanks
Henry
Thanks
Henry
Wanted: Stylus or Manual for Ortofon DS522.
Also interested in any record cutting or pressing items for sale in Australia.
Hey Nigie, have you the dimensions of stylus holder hole ?
- dubcutter89
the stylus for the mono ortofons is 0.75mm diameter straight solid ruby (saphire...), so the hole in the armature is just a little bigger.
also needed is the so called collet ring, which goes around the armature (conical) reducing its inner diameter so that the stylus is held in its place.
original stylus # is 329 (without SH which stands for aluminium SHank..)
if anyone knows a source, old stock, new manufacturer or has some lie around please let know..
or might be possible to ask apollo if they do a batch of 329 without shank...
lukas
lukas
- Aussie_cutter
Hi
I understand that the sapphire stylus for the DS522 has a length of 4 mm, cylindrical shaft. The diameter of the shaft is specified to be between 0.75 mm and 0.73 mm.
Does anyone have a photo/drawing of the collet used to hold the sapphire? I think mine is missing.
H
H
- dubcutter89
I will take some pistures of the head, connector and stylus mounting next time I come to my cutting room (next week)
L
L
- powerstrip
Getting to this point is still a chore- You need to think about how to remove the 2 layers of rotating plates to gain access to the armature.
Removing the collet without tool?
Dip a toothpick penetrating oil, touch tip lightly around upper edge of collet as head sits propped in upright position,wait a couple minutes, lightly pull away collet with gentle rotation.
Now you must mount stylus and be sure azimuth is correct, which I am unsure of how to precisely set/adjust.
Here is a pristine stylus for the ortofon dss d22
Dont get exited yet but i think someone is about to cut some for us...stay tuned
NOW, Does anyone have a picture of this freakin' impossible to find TOOL???
- powerstrip
Attention:
Look no further for ortofon DSS 522 Styli!
I convinced the people at apollo masters to cut more.
Contact Sam at apollo/transco and tell her you want a stylus for dss522, reference ortofon styli number 329 (WITHOUT SHANK)
She will ive back an estimate, and is saying they are basically ready to cut as soon as she gets some calls about it.
www.apollomasters.com
USA : 951-849-8831
USA : 951-849-8831
