Polycarbonate 12" - 10" blank records searching
Hello, I am searching someone that sell polycarbonate from 12" or 10" round transparent , thickness 2mm .
Thanks.
Thanks.
Re: Polycarbonate 12" - 10" blank records searching
I would be interested too.
mm.
mm.
- ROLANDJAYS
Where are you two located in the world?
I ask because shipping might cost too much
- pellegrino707
Why Polycarbonate?
MyShank sells 2mm transparent PVC (as well as black PVC), much softer and way less noisier than PC, and also better for your stylus (longer lifespan).
I tried PC but i couldn't get a decent result, it is really to hard to get a good sound.
Which type of cutting head do you have ? And about type of stylus, what do you use ?
Would the Myshank blank be better for embossing (and with a longer styli lifespan) than polycarbonate or is your experience
just with cutting?
just with cutting?
I am in Texas, US of A. And I am looking for PC not to cut, but to emboss. I am not quite ready to work with expensive diamond cutting styli
mm.
mm.
Yes, a lot better.Big Al wrote:Would the Myshank blank be better for embossing (and with a longer styli lifespan) than polycarbonate or is your experience
just with cutting?
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
Wait a minute. So - one can use your blanks to emboss? That woudn't require a diamon stylus or would it?The Shank wrote:Yes, a lot better.Big Al wrote:Would the Myshank blank be better for embossing (and with a longer styli lifespan) than polycarbonate or is your experience
just with cutting?
Michaela
For example :
jesusfwrl wrote: I am impressing with the GoodTurn stylus on black PVC. This is one of the blanks made by Myshank. They are normally meant to be cut with a diamond, but I was experimenting with embossing on them to see what it will sound like. The sound is very good, but there is a lot of stuff coming out which is getting lodged between the stylus and the groove walls causing sudden bursts of surface noise. The obvious solution is a vacuum suction system which is the next thing I will be implementing on this setup.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
Why is there "stuff coming out" if no "stuff" is removed (imprinting) ?The Shank wrote:For example :
mm.
mm.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
you can use the myshank blank for either cutting with diamond, or embossing with sapphire/ruby/steel/tungsten
in my experience polycarbonate is a little bit cheaper, though "harder" than the myshank blanks. they have a softer feel to them.
I use the myshank blanks for cutting with diamond, and polycarbonate for embossing, as I save a few bucks making the polycarb blanks myself.
Cool. I am going to order some blanks from myshank and try it out. But I have 80 or so laquers to work with in the moment - so I am good.tragwag wrote:you can use the myshank blank for either cutting with diamond, or embossing with sapphire/ruby/steel/tungsten
mm.
So nobody here can organize a serious sale service of transparent policarbonate blanks ?
- ROLANDJAYS
I'm interested in supplying blanks to the community.
Pm me .
Pm me .
- dubcutter89
Vinylike in Germany may has some:
http://vinylike.de/index.php/store/products/recording-disk-pc-transparent/
Lukas
Lukas
It's the no brainer !
My shank blanks are nice
Quiet cuts with diamond
Not much lamp heating is required
Try and source your own blanks and it's expensive
I've tried my self it's expensive.
I'm interested in supplying blanks to the community tooROLANDJAYS wrote:I'm interested in supplying blanks to the community.
Pm me .
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
