Dual Table Presto on ebay
16020856926
Looks like a model M w/ 2 j5's! Recapped Amps, and 2 heads!! Good system.
- cartridge-repair
prest
This item number does not come up. Need 12 digits.
West-Tech provides service and parts for record cutters and phonos for the hobbyist, adventurer and enthusiast. Thanks for your patronage. Gib
Presto Phono Record Vinyl Recorder
Item number: 160208569265
Bidding has ended for this item
Starting bid: US $795.00
Ended: Feb-20-08 13:56:13 PST
Ships to: United States
Item location: Eugene, OR, United States
Starting time: Feb-13-08 13:56:13 PST
Seller: prestocollector( 6 )
Feedback: 100% Positive
Member: since Sep-16-06 in United States
Presto model M phonograph disc recorder. Circa 1936 era. This is a unique model, contains two model J5 turntables. Amp has been re-capped, and the heads re-built, although due to their age there is a little distortion in the low bass. Requires external speaker. This would be a great collectors piece, rather than a production recorder. Case has been re-covered in vintage Fender material. Due to it's age, sold as is with no warranty. Shipping by UPS not included. Packing charge of $50.00 by UPS store.
Sold in the United States Only. Shipping weight approx 90 pounds. From 97402
VISA or Mastercard accepted directly, or Check as cleared.
For more information on this model and other PRESTO equipment, see the Presto History page on the web at
- buckettovsissors
Dual Table Presto in the Real World (Los Angeles)
Been in elderly man owner's house forever, so drop him a line thru the website musicmanmurray.com. He has pics and specs, but it WILL have to be rebuilt, reflocked, have the amps gone over, get new tubes, have the rubber remade.
But both the motors work and have been kept in good shape, the platters are still flat and both cutterheads work as far as we cut onto an old fiber blank.
Only comes with the 96 LPI drive installed (uses a track under the turntable) and both playback and record arms are pivotal-style. Cannot do lead-in or lead-out grooves, but is a cool vintage World War II live concert-hall performance check recorder anyway.
Ask him for prices, but don't insult him, cuz you can't restore what you ain't got.
