Clear Polycarbonate discs for sale $3.00
prestok10
Post: # 44887Unread post prestok10
Wed Nov 23, 2016 2:57 pm
I have approx. 80 - 10" discs for sale ready to cut. 0.030" clear polycarbonate with center hole punch and a secondary hole punched for those cutters that have a registration pin. Specially made for use as picture discs. Peel the protective sheet off one side and its ready to cut. Peel the protective sheet off the other side and its got an optically clear adhesive to stick your picture to. Glue two of them back-to-back for a two-sided picture disc. Each side will be clearly marked if its the cutting side or the adhesive side. $3.00 each or 5 for $20.00, plus postage. Email me {dangerdanger (at) sbcglobal.net} or post here. I accept PayPal at the same email address. If demand exceeds the 80 I have, I can do another run. I've tested these with a stellite cutting stylus and pre-lubrication using Turtle Wax spray plus softened with a heat lamp and I get a really good cut.
prestok10
Re: Clear Polycarbonate discs for sale $3.00
Post: # 44928Unread post prestok10
Fri Nov 25, 2016 5:09 pm
I meant to say 5 for $10.00.
